Ol' Blue '92
Discussion in '1989-1995 Build-Up/Project Threads' started by planemos, May 5, 2010.
  1. planemos
    planemos Toyotaholic
    British Columbia
    I have some more pics to show. Things are looking good. I hope I can get it driving soon.
    Getting the 98 Taco rad support to fit
    It is taller
  2. planemos
    British Columbia
    I had to bend over the edge on the bottom of the radiator support as well as cut some of the top of the frame off.
  3. planemos
    British Columbia
    Pic of the bed getting tubbed. I need to seam seal:
    And another look at my clutch setup:
    So I still need to bag the front. I am thinking it won't take that long. Just need my upper brackets to arrive. And then finish tubbing. Build some rocker panels (btw I started on the driver's side). Seam seal. Bondo. Primer. Put the interior back together. And get it started (put in alternator radiator fluid).
  4. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Dang looking good bro. Coming along pretty quick.
  5. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    nice! whats the plan for the rockers then?
  6. planemos
    British Columbia
    I will try to get some pics at some point of my rockers.
    The plan is using eighth inch sheet steel that I have to make something quite strong. And I am cutting the bottom of my doors off because of rust. And doing that will make my rockers look clean. I mean there won't be any part of the door to add to the shape of the rocker. Kinda hard to explain but I will definetly take pics. And if a bod drop is in the future then the rockers will be strong enough to handle it.
  7. planemos
    British Columbia
    How it is going
    With 1 inch cut off the bottom of the door and eight inch material for the rockers:
    Underneath the rocker panel:
    And rear tubs as high as I can make them:
  8. Dgerfan55
    lake elsinore CA
    94 pickup
    Looks good bro. Man you improved so much with your welds and work since the very beggining. Keep it up. Whats next?
  9. planemos
    British Columbia
    I think I am going to have to use the 98 taco rearend I have just sitting here. Because the rear airbags are really close to the wheel. May need spacers too. And my taco will be able to get a narrow rearend from this truck. That is just one thing I have to do on the list.
    More pics:
    Messy interior
    I also need to tub the passenger side and do that rocker panel. And I need tires. And I need to make front bumper brackets. And I need to line up the front end fenders and rad support. And get it to start by hooking back up all the wiring.
  10. planemos
    British Columbia
    progress pics
    Just some pics of the driver side firewall tub and tacked in inner fender:
  11. planemos
    British Columbia
    pIC
    Things haven't been happening as quick as I would like. But I figured I would take a picture today anyway. I have put in my 98 Taco rearend. It's wider so my wheels won't touch the airbags. I still have to bag the front sometime. But I got my lower arm bushings out.
  12. Dgerfan55
    lake elsinore CA
    94 pickup
    looking good bro, keep it up
  13. nxrunner
    nxrunner Member
    Marksville La. Working in Carbondale IL.
    92 Xcab ~ Rare 2000 XCab StepSIde
    Looking good man, keep up the hard work>
  14. planemos
    British Columbia
    slowly...
    It's been a while because I got distracted by this:
    1988 Supra turbo (7M-GTE)
  15. planemos
    British Columbia
    Front bags
    But just the other day I finished welding the front upper bag mounts. Today I just bolted up the arms and spindles. Still need to drill holes for the lower bag mounting bolts (through the lower arms). I am excited to air it up and push it around lol
  16. jctoy29
    jctoy29 Addict
    surprise,az
    U got a any plan s for the supra
  17. Dgerfan55
    lake elsinore CA
    94 pickup
    Nice job. Clean car man. Whats the plans for it.
  18. planemos
    British Columbia
    plans for the car: drift car
    It is my first car ever. I've only ever owned a bunch of Toyota trucks.
    I like drifting and it is easier to drift a Supra then a pickup. I want to get
    coilovers and rims for it. And increase the steering angle. I am quite
    happy with the amount of power it has. Already a large step up from
    my 4 cylinder truck!
  19. Dgerfan55
    lake elsinore CA
    94 pickup
    Nice man sounds good. So does this mean the truck is going to be put on hold now? Also where did you you get your tubes from? How much?
  20. IronNam
    haven't peeked at this in a while, she's looking good.... more parts more goods hehehe
