OJ's 1985 Refresh Project
Discussion in '1984-1988 Build-Up/Project Threads' started by OJ's DNA, Feb 17, 2009.
  1. SUNSETJOE
    SUNSETJOE Enthusiast
    San Diego
    81 SR5 longbed
    The bumper I have is for an '87-'88 2WD Toyota Pickup. Be sure to get the bumper brackets and the lower valance with it. I used my original lower valance, but it took some redneck engineering to get it on.
  2. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    sweet man, get some out door pics with some sunlight
  3. blazinrola80
    blazinrola80 Member
    lmk i have the bumper laying around..
  4. HumanResource
    HumanResource Member
    If all the trucks were the same style and paint, think of how easy it would be to work a beater back into shape.
    Or is that too socialist for thought?
    THEY'RE WATCHING US!!!
    I'm just up Beach from you in B.P. MiniToys are fun!
    Count me in if you're gonna drop it, I'll bring a 6 and good times.
    Maybe we'll have a drop party!!!
    Groupbuy?
  5. OJ's DNA
    OJ's DNA Member
    So Monday I took of from work so I coulpd spend all day installing brakes, shocks, spindles, lowering blocks and bushings. I have a few questions:
    1. I'm using a lift so I can get off my knees and work on it but lets say its on the lift with the tires hanging and I'm installing the rear blocks and bushings - should I remove the shocks and loosen the u-bolts, then remove the bolts that hold the bushings for the leaf springs in first, or what would the preferred order be for this job. I've never worked with leaf springs and I'm not sure how much energy is stored in those things.
    2. If your standing underneath the truck facing the rear, what direction would you rotate the torsion bars for the truck to move upwards or downwards?
    Thanks - anything else I need to have or should think of before Monday?
  6. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    once its in the air there shouldn't be any "spring" in the leafs.
    staring at it as above the pass side would go clockwise and the drivers counterclockwise. you just need to loosen the torsion bolts.
  7. OJ's DNA
    OJ's DNA Member
    Thanks Buyrnza, much appreciated. :waytogo:
  8. OJ's DNA
    OJ's DNA Member
    Okay, see here she sits after a trip to the alignment shop and the following installed items by myself on Monday:
    Belltech 2" spindles
    new rotors / pads
    upper & lower ball joints
    belltech shocks
    new brake lines
    3" blocks in rear w belltech drop shocks
    bushings replaced in rear
    starions put on 16 x 7 front / 16 x 9 in rear
    Notes: I'm happy with the overall look / drop. I do wish I would have meesed around with the torsion bars first, as I might not have needed the drop spindles at all - I know you advised me of that BYE. Anyway my only issue is the rear Starions, I really did not expect them to stick out from the truck like they do, I like my wheels tucked and really dispise this look right now. As far as I know I have two options:
    1 - roll the fenders to accomodate the wider wheels
    2 - Buy some 16 x 7 Starions for the rear
    I'm inclined to seatrch for the 16 x 7's and if anyone wants to trade some 16 x 7's for these that would be great to, again when I look at the pics from Blazinrola's truck they tucked nicely, maybe he rolled the fenders.
    Anyway here she is, its raining and the pics aen't great but it gives you an idea.
    fat ass tires in rear - I don't like it...
    Blazinrola's truck with the same set-up
  9. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Looks like he had the 4X4 bed and rolled it aswell... Looks good tho! I'll keep an eye out for the 16X7 here.
  10. Toyo Trucker
    Toyo Trucker Addict
    Just roll the fenders.
    You could also try getting a different offset rear rim.
  11. OJ's DNA
    OJ's DNA Member
    Thanks BYE, really appreciate the look out! I think I'd be happier with the same size wheels as the front.
  12. OJ's DNA
    OJ's DNA Member
    I think you called it BYE, upon further inspection this morning it appears that the jap bed has almost no fender flare at all, it appears that it has a flare but its more a visual look than an actual flare. Remember I had the american bed with the same meat on the fender as Blazinrola but switched it out for this Jap bed as it was lessed damaged, had less rust, etc. The point is that there's not enough fender to roll, or it can't be rolled out as much as I need it to, so I'll be looking for 16 x 7 starions. I did find two on ebay for 150.00 - I'm just about tapped out on spending $ for this truck but...thanks to all for the help. :cool:
  13. yotarip
    yotarip Veteran
    Your truck looks great. I may be able to help you out on the 16x7 rims.
    Let me see what I can do.
  14. Sam78
    Sam78 Enthusiast
    Oceanside
    78 toyota longbed 5speed 20R
    Q
    Just curious
    What was the bill from the body shop? For body work and paint.
  15. OJ's DNA
    OJ's DNA Member
    Well it's hard to say because I did some work for this guy last year and he owed me the body work and paint in return so I didn't pay anything except for the jap bed ($200 on craigslist) and the paint at $125 - someone else can chime in but this was easily about $2,000-$2,500 in body work and paint I believe.
  16. Sam78
    Sam78 Enthusiast
    Oceanside
    thats what I was assuming, thanks
  17. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    looking good!
  18. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    hey man, keep the wheels but go with a different tire out back....
    i have a 205/55 in the rear and its good enough to tuck a 6 inch drop back there :waytogo:
  19. SD YOTA
    honestly, unless yer running turbo or massive power, they dont need much tire out back. gives you a bit more power back too.
    i was running the 16x9 rears and a 245/50 tire....... it rode nice but man did it rub and slow the truck down! :lol:
  20. OJ's DNA
    OJ's DNA Member
    Wow, see those last two trucks is what I want - nice and tucked, but mine is not even close, I think the Jap bed fender flare is that much different.
    I do have one correction to make, the rears are 16 x 8 with 215/55/16's - initially I had said they were 16 x 9 but I was mistaken.
    Are those 16 x 8's in the rear of the white truck?
