nvrenufedge's '93
Discussion in '1989-1995 Build-Up/Project Threads' started by nvrenufedge, Feb 10, 2009.
  1. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    No tonneau, but I am trying to convince my wife to let me get an alarm with motion sensors.
    And I do plan on taking alot pics. If he works on it when I'm not there, he said he'd take pics.
  2. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    how do you plan on protecting it from; elements? are you gonna rhino line it or something?
  3. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    Yeah, Line X I believe.
  4. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    Pics of the bedbox so far...
    front of box...subs will be mounted on this wall
    this is the bottom and sides....the outside will be 2 layers thick, 1 1/2"
  5. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    lookin good dave!
  6. IronNam
    Dave doing work! keep it up sir!
  7. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    Oh, I'm not building it. A buddy of mine is, but I am helping when I can.
  8. joeynational
    PHX,AZ
    91 2WD
    what are you going to push these with?
  9. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    A Rockford Punch 500-1 running at 1 ohm. Then I'm going to use a Punch 400-2 (100x2) for the door speakers which will be JL's XR series components.
  10. burnzya
    bodied 73 hilux
    dave you know i get confused when ya use all those fancy terms!!!!!! :brickknock:
    :D
  11. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    :ROFL: Sorry, Bernie.
    Pics of the box today...
  12. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Dave what kind of box is that, regular ported? Or an ABC type? Was asking cause the flower inside on one of the ports.
    Also your port opening looks a little on the small side. Might limit port flow and create port noise. (no offense to your friend helping you out.). Do you have the specs for the box? Id be interested to check it out. You can PM it if you dont want everyone else to know. Just wondering all the #s. thanks man and no offense, looking real good.
  13. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    Yeah, just a regular slot ported. The air space is just over 1.25 cu ft per side. The port is narrow but long. He is going to router the edges of the port for better air flow, some of the pieces are just sitting there for now. The flower looking piece and the rounded piece are for bracing to make it more sturdy and so it doesn't flex. He's been a pro instsaller for 13 years, but I know you mean well, its cool.
  14. IronNam
    The making of a sexy box. lol
  15. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    My buddy picked this up for me today....its starting to come together...hehehe
  16. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    Plexiglass came into today, so he said he should have the box fully built tomorrow. Except for the Line-x, that should happen later this week.
  17. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    Nice! Spendy battery. This is all going to be nice though man. Can't wait to see it done.
  18. joeynational
    PHX,AZ
    91 2WD
    are you running dual batts? or is this replacing your current..I would love to see how you wire this up if your going with two batts
  19. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    The friend of mine that is building the system for me has a friend that sells optima's, so I got it for only $75.
    Nope, replacing the old one. I can help you with wiring 2 batts, its not that hard. You basicly wire them in parallel (+ to + and - to -). One system I helped with a while back we put a second batt in the bed, drilled holes in the bed and ran the cables along the frame up to the first batt. We used wire loom and eyelet zip ties and mounted them to the frame. We also wired up a solenoid between them so when he runs the system without the being on it run off the second batt.
  20. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    More pics of the box today...
    and this is the color of plexi that be around the subs and ports...
