No start
Discussion in 'Engine/Drivetrain' started by 4lo4fun, Mar 29, 2020.
  1. fred heath
    fred heath Addict
    Raleigh, NC
    You mentioned changing out the coil. Did you also change out the igniter? or are you still using the one that was fried?
    If you’re still using the old one, that’s probably why you can’t get it running.
  2. 4lo4fun
    4lo4fun Enthusiast
    Layton, UT
    78 hilux
    Fred, I replaced the whole unit. I did notice better spark.
  3. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    You said you noted fuel in the chamber. Have you checked on fueling after assembly. Is the carb pumping?
  4. 4lo4fun
    4lo4fun Enthusiast
    Layton, UT
    78 hilux
    @Pearce, yes the carb is pumping.
  5. fred heath
    fred heath Addict
    Raleigh, NC
    B53EFD9F-A63B-4C0D-A8E3-223CCC6B71DC.jpeg You’re getting fuel. I’m guessing your timing is roughly where it should be. The only thing left is your distributor and coil/igniter. I’m guessing you have the fully transistorized ignition (no points).
    It’s time to get a good repair manual that shows step by step troubleshooting. Particularly the igniter. You’ll need a volt meter and ohm meter to do the tests correctly. Usually both functions can be performed with a single meter. You can buy them for about $20 at Walmart.
    Check the length of your signal lines. They should be about 22” from the igniter to the tip of the green plastic distributor plug. If much longer, you may have to do a loop of some kind.
    I’ve attached images of a NOS igniter (in front) and my backup coil/ igniter which has already been tested and works fine. I’m a firm believer in overkill.
  6. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Screenshot_20200405-124309_Chrome.jpg The ignition system starts a little before that page on the service manual I sent a link to.
  7. 4lo4fun
    4lo4fun Enthusiast
    Layton, UT
    78 hilux
    20200405_151221.jpg 20200405_151221.jpg Fred, yes, I'm getting fuel and spark now that I've swapped to a different coil/ignitor.
    I do have the Haynes manuals for the 78 pickup and the truck the engine and coil came out of.
    This is the one I've wired up.
  8. 4lo4fun
    4lo4fun Enthusiast
    Layton, UT
    78 hilux
    I also have meters to test everything.
  9. 4lo4fun
    4lo4fun Enthusiast
    Layton, UT
    78 hilux
    Soooooooo, I grabbed the battery from a customers car and she fired right up!
    fred heath likes this.
