new gauge cluster
Discussion in 'Interior/Electronics' started by Lilnado, Oct 9, 2010.
  1. Lilnado
    Lilnado Enthusiast
    NC
    1992 toyota pickup
    i got a v6 4 runner gauge cluster i wanna know if its plug and play or if i got do slight modifictations oh both my stock and this one are electric and my truck a 22re
  2. Lilnado
    Lilnado Enthusiast
    NC
    1992 toyota pickup
    does anyone know where theres a write up on how to do the tach i realy need that
  3. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    If you install the V6 cluster your tach will be off and you will need to unplug YOUR oil pressure dummy sender, if not you will blow the gauge. You will need a new oil pressure sender designed for that cluster. untill you get one leave yours unpluged.
  4. IronNam
    basically trade it for a 22RE one.
  5. tek-x
    tek-x Newbie
    How do u get the tach to work. I put a cluster on my 89 and everything works except the tach and oil temp
  6. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    these topics have been covered many times, do a search for em...but
    you need the right oil pressure sender for the gauge, just run a wire from the coil to the + screw on the tach or the P screw i forgot which one i put mine on
  7. topcop182
    topcop182 Addict
    Colorado Springs Colorado
    1993 single cab 2wd
    yeah, there are a few right ups about doing it here, but it involves resetting the cluster for a 22re. You would be good to sell this one and find one from the same motor and year that your truck is.
