Need more low - ground clearance??!
Discussion in 'Suspension/Chassis' started by Baja_Mutt, Nov 17, 2020.
  1. Baja_Mutt
    Baja_Mutt Newbie
    Salem, Oregon
    93 base
    Hey guys, I ordered a set of 15s and low profile tires, and I'll have more room to go lower (already on a 3/3 drop on 16s and big tires). I'm staying static, and I'm worried about starting to scrape the shock mount on the rear axle on things.
    Is there a way to flip it so the shocks mount on top of the axle? This would keep me from dragging the ends of my ubolts too. Thanks!
  2. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Are you just on blocks, or do you have lowering springs installed?
    I'm at like a 4/5 drop and the only thing close to the geound is the guard bar under my trans.
  3. Baja_Mutt
    Baja_Mutt Newbie
    Salem, Oregon
    93 base
    I'm on blocks right now, but I'll be installing drop springs and lowering c/a eventually.
  4. Justin Danger
    Bay Area Peninsula
    Then you should be good, other than possibly banging frame with your axle or tire rub in the front wells
  5. Baja_Mutt
    Baja_Mutt Newbie
    Salem, Oregon
    93 base
    I've got fairly stiff shocks right now and I cut the bump stops down, I haven't noticed any issues but I'll be cnotching the frame when I replace the bed has anyone done a side dump exhaust on a std cab this low?? I don't wanna do the bedside exit but I don't think risking sandwiching the pipe between the frame and the ground is any better
