Busy day today!! Preliminary gasless flux core results Both crossmembers notched. All done, sits the same but now it wont bottom out. I think the hitch will drag before the suspension bottoms out Damn, just noticed I still need to cut the hanger, lmao
Also have color matched custom faded 4wd fenders. just waiting on the corners to install everything together.
On my drive home I got a flat tire tire needed to be replaced FTL so I got a 2 new tires, one for the truck and one for the spare. and on the plus side. Finally the complete 4runner front end using the stock 2wd core support. Going to be getting the amber side markers, I don't want clear side markers.
Full stock leaf pack, 3" block plus re drilled hanger 1.25" so 4.25" rear and turned down torsion bars to match. comparing the height to a stock toy, from ground to top of rear fender is 28" my truck was 23.25" difference of 4.75" some where I'm gaining .5"
Yesterday was a good day. Truck now has Power windows, factory power locks, and power mirrors. SR5 power door panels Took a few minutes but was able to strip pull the man door harness from the donor truck. would not have been possible if other people had not gutted the truck for me Door harness installation Since I wanted OEM connections I also swapped out the entire door locking mechanism. All done!! I ran the wires differently but they are nice and tucked away out of sight. wiring took longer because I tested the everything off the truck before installation, no need to install broken parts. Everything works, truck now has full power.
