My Silver Toy
Discussion in '1989-1995 Build-Up/Project Threads' started by toy_spd, Apr 20, 2011.
  1. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    I like what you did under the hood. Does clean it up nice. Any chance you have a write up on the clutch start switch? What are the plans for the interior also?
  2. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
    IT WAS NICE MEETING YOU TO MAN :waytogo:
  3. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    It was a pleasure meeting you as well.:clapping:
    Its tempting to drop her down a few more inches,:runaway: but at this time I cant go any lower:duh:
    When you find a donor truck, take the switch and take the harness behind it.
    The more wire you have the simpler it is, I had to extend my wires.
    The switch is super simple to do, 3 wires to the switch. 2 of them are the same as the ones going to the clutch switch, white/black stripe, black/red stripe and then there is another a black and yellow stripe.
    The 2 that are the same color, just tap into the other 2 wires same color at the clutch switch by the pedal and the one other wire, is wired to 12v ignition, that's it. When ignition is turned off it resets the light automatically. The switch lights up only when pressed in.:waytogo: If you don't turn off the ignition you can restart with out pressing the clutch in.
    I just looked at the wiring diagram for this, and its wired the same way as I described:clapping:
    As for the interior, leaving it pretty much how it is. the idea of tilt crossed my mind. but I don't see a need for it.
  4. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Very nice man. Looking good.
  5. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    A/C Update:
    The AC Amplifier controls Idle up and turns on the AC Compressor. Using what I had sourced, all 22RE Parts, the 22R engine harness would not get a Idle up signal. so I made a jumper plug so it would work. AC Compressor on Idle up is engaged. But I didn't like the fact that it was not factory original.
    Today I was able to source the AC Amplifier for a 22R, at 1st I did not get the entire harness, but later I went back to get it. You need the AC Amplifier and harness for a 22R in order for everything to work properly. If you don't have them, it will still work using a Jumper wire between the AC Compressor wire and the Idle up wire.
    Here are Pictures so you can see the difference.
    This is located on top of the Evaporator under the dash. You turn the Knob so tell it when to Idle up at a certain RPM.
    22RE PN# 077100-3391 on the LEFT and 22R PN# 077100-3411 Right
    22R PN# 077100-3411 Notice the additional resistors.
    22R Harness plugged in. notice the different wire colors
    22RE Harness
    This is the 22RE plug that plugs into the vehicles factory harness, it is wired different than the 22R harness
    This is the 22R harness plug that plugs into the trucks factory plug. As you can see it dose not have that jumper cable and is using different colors for wires.
    Now the AC is 100% OEM. no jumper wire to make it work.
    No one would ever know the difference between the 2 set ups.
    Its just personal preference that I wanted 100% OEM.
    No Micky Mouse stuff.:waytogo:
  6. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    added this OEM Toyota Security Indicator plate, just need to wire it up.
  7. IronNam
    very cool!
  8. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    Factory Fog light switch,
    [​IMG]]
    Now all the button plates are full of factory switches :D
  9. Dgerfan55
    lake elsinore CA
    94 pickup
    Now its time to do mine for me. Good job man
  10. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    Just say when:waytogo:
  11. Dgerfan55
    lake elsinore CA
    94 pickup
    When!!! Plus i got to get those mirrors from you.
  12. flacostaco
    87 pickup
    i got ur grey cover
  13. Choco Taco
    Choco Taco Member
    what does the clutch switch do ?Where did you find a fog switch from ?
  14. flacostaco
    87 pickup
    clutch cancel is for starting the truck with out steping on the clutch comes in handy while workin on the truck:waytogo:
  15. Dgerfan55
    lake elsinore CA
    94 pickup
    What grey cover do you have?
  16. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    update:
    truck now has the 4runner A/C fan for the condenser.
    Its wired to come on low when the A/C is on, and when the idle up kicks on, it will go on high
    reason for this is so the temp dose not rise when in traffic on the freeway.
  17. Dgerfan55
    lake elsinore CA
    94 pickup
    Very nice man, small details you do but make a big difference
  18. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    yup, its the little details that make a big difference.
    The engine bay.
  19. Dgerfan55
    lake elsinore CA
    94 pickup
    Very clean. mine will be like that some day
  20. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    thanks, yeah just keep cleaning yours every time you have down time and it will get clean
