My '78 "Pickup"
Discussion in '1976-1983 Build-Up/Project Threads' started by Dan McBoost, Jul 15, 2014.
  1. Dan McBoost
    Dan McBoost Enthusiast
    NY
    78 Pickup
    ... and the 91 pickup is gone! Yay. Now do I keep this bay open for random repairs and quick projects, or bring over my 78 to start the swap... :thinking:
  2. Utility 77
    Utility 77 Enthusiast
    Oakdale
    1977 Reg Cab w a utility bed
    Just read that whole thread, great project.... If you would sell that extra driver window ???
  3. Dan McBoost
    NY
    78 Pickup
    Thanks, it is getting there, slowly.
    Sorry, no. I keep (horde) at least one of everything I can for the cars i own.
  4. Dan McBoost
    NY
    78 Pickup
    I moved my mk2 supra back to my storage garage since I have all of the parts needed for the trucks swap. Then we bought the RN28 back to the "shop" garage. Today was a good (but long) day!
  5. Dan McBoost
    NY
    78 Pickup
    So I have both 22REs on engine stands and starting swapping the new parts off the bad engine over to the good one. Only had one thing stop me so far, the crank bolt on the good engine. My impact would not touch it. So we held the flywheel with a pry bar against the engine stand standoffs that mount to the block, then used my big breaker bar and a 6' pipe. With a very loud BANG it was loose. Now I can finish the parts swap this week.
  6. Dan McBoost
    NY
    78 Pickup
    Most of the good and better parts are on the good 22RE as of today. I am a bit behind, but will keep trucking along.
    I will pull the head off of the bad 22RE to see what happened.
  7. Dan McBoost
    NY
    78 Pickup
    I reorganized the garage to get ready for the swap last weekend. I have car shows to shoot both day this weekend and then a cars and coffee next Sunday. I did finally find a missing headlight bezel and picked it up. Sometimes it is the little things.
    I will be concentrating on getting the truck done after this weekend. I have a small chance, but am very interested to bring it, swap complete, to toyotafest CT this fall...
  8. Dan McBoost
    NY
    78 Pickup
    After a couple of years looking to replace a missing headlight bezel, I found one but I am now on the fence. I polished them up and put them in, but it now it looks too "pretty". I think I am going to remove them...
    Garage is staged and things are off and ready to go for nickel plating.
  9. jetas
    Im not using the bezels on my grill and i like it better.
  10. standfast
    standfast Newbie
    Sweet! What all are you nickel plating?
  11. Dan McBoost
    NY
    78 Pickup
    Yeah, I will be removing them. At least I have a full set now. I cleaned them and will box them up.
    intake plenum,valve cover, a few brackets and such.
    jetas likes this.
  12. Dan McBoost
    NY
    78 Pickup
    Spent the afternoon pulling the engine and trans Friday.
    today was HOT, i just cleaned up the messes.
  13. Dan McBoost
    NY
    78 Pickup
    I spent today... cleaning...and sand blasting... oh and my back knows all about it. ugh.
    There was a heavy thick amount of oil build up on the front crossmember/subframe. Some time with simple green and plastic putty knives it is finally pretty clean.
    I sandblasted some of the stuff i am going to nickel plate (I am going to paint the throttle body and heat shield). Tomorrow I need to remove the PCV tray to clean it out. Once I get it off I am going to drill and tap to install thread locked bolts.
  14. Dan McBoost
    NY
    78 Pickup
    I was all over today on car projects, but did get to rip off the PCV tray and clean it out. I also tossed in the clutch pedal assembly and saw that I need a new clutch master cylinder. I also pulled the oil pan and pickup off of the 20R.
    I am swapping the oil pans tomorrow and if I have the time, drop the engine and trans into place to figure out the other unknowns.
  15. Dan McBoost
    NY
    78 Pickup
    A few photos of progress. Not enough to really know what was done haha. Sandblasting, die grinding, priming and painting the stuff not getting nickel plated. I also cleaned the lower subframe enough to actually repaint it, heh.
  16. Dan McBoost
    NY
    78 Pickup
    My seat was dropped off for the upholstery repair and plan. The stuff has been at the nickel plater for a few days. i also ordered CNC half moons. i hope to get the engine parts back together this weekend.
  17. Clay
    Clay Member
    Ohio
    93 Pickup
    That's awesome. Can I ask how much the upholstery on the seat costs?
  18. Dan McBoost
    NY
    78 Pickup
    Thanks! $160.00.
    jetas likes this.
  19. Dan McBoost
    NY
    78 Pickup
    Since the truck's factory seat was cracked (new mexico and all), the owner put a locals home made navajo blanket over the seat. it was still in the truck when I got it, YES! The side facing up was terribly faded, but the side facing the seat was fresh as new. I asked my upholstery guy about replacing the torn faces of the seat (bottom and back) with the good side of the blanket and he loved the idea. He talked me into replacing the sides with black vinyl which I should have planned, doh!
    He dropped it back off to me today and boy am I happy with the plan.
    Here are his photos of the progress:
    Not bolted back togther, but set up together:
    1982, RN23CB and _Rigo_ like this.
  20. Clay
    Clay Member
    Ohio
    93 Pickup
    that's a fun idea.
