My 1994 4x4 Build
Discussion in '1989-1995 Build-Up/Project Threads' started by Roland Deschain, Sep 6, 2021.
  1. Roland Deschain
    Roland Deschain Enthusiast
    The new windshield installed and the tech appears to have done a good job with the trim.
  2. Roland Deschain
    B62D6DB7-6B45-4B50-84A0-7146980FE102.jpeg Dropped off seat at the upholstery shop this evening, hope to get it and the door panels back soon.
  3. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    looks like safelite did well with the trim!
    Roland Deschain likes this.
  4. Roland Deschain
    Got my braided steel brake hoses today. 7133CEB4-31EC-47F2-87C1-49FFA20B6FDE.jpeg
  5. Roland Deschain
    Be
    Yeah I was worried about but did ok. I’ll post a pic of the trim, it’s not dented or bent but apparently the trim has or had rubber strips attached to it and some are missing. Some were missing before the replacement.
  6. Justin Danger
    Bay Area Peninsula
    totally, my trim has all the rubber rotted off of it. But that is good to know, I could use a new windshield and always worried about those delicate chome stips.
  7. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    This makes me want to do mine! Mines got a rock chip big enough where it was starting to whistle! Haha
  8. Roland Deschain
    Husky Liners showed up today. 1CCA2829-89BB-4B79-939B-E0EB13CF740C.jpeg 7D6F4C76-9238-48F9-BB83-2DD1B26D9AD9.jpeg
    Erwin Merida and Perkolator like this.
  9. Roland Deschain
    Decided to start on the ball joints today.
  10. Roland Deschain
    The uppers have to have the bolts pressed in as they are splined. Fortunately I still have an old arbor press around. Don’t know if all uppers for the Yotas are this way or not. Of course you could just hammer them in. 1F9B5FB3-5D7C-438E-AA2E-2E66D0C8E943.jpeg
  11. Roland Deschain
    I did the upper first and then the lower, nearly done. 632398B8-5649-4554-98AC-8BE608487112.jpeg
  12. Roland Deschain
    Buttoning everything back up. Installed the Goodridge passenger side stainless brake hose while I was in there. You have to reuse the hose locks of course but you also have to reuse the large e clips off the old brake hoses. I’ll do the driver side Monday night the Lord willing.
  13. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Where'd you pickup the braided brake lines at? Last year I had my wheels off for replacing the brake calipers I definitely noted that I should be prepping for a replacement on those old flex lines.
    I don't think I ever noticed the BJ studs are pressed in, I installed BJ spacers when I did mine and they use regular bolt hardware.
  14. Roland Deschain
    I assume it probably varies by manufacturer on the balljoint studs. I'll have to find the vendor for the brake hoses, they seemed to be out of stock everywhere then I just found them on a internet search. The part number is 21152 and they were Goodridge brand, says application is 1984-1996 4x4 pickup.
    Perkolator likes this.
  15. Roland Deschain
    Got the rear brake hose installed tonight.
  16. Roland Deschain
    Hey it was Evasive Motorsports that I bought them from.
  17. Roland Deschain
    LC Engineering exhaust system just arrived having it installed and an alignment done tomorrow if everything works out. 68B26E93-CC83-4F11-9B19-C1B3FAB10783.jpeg
    Erwin Merida likes this.
  18. Roland Deschain
    9FAE2548-56DE-45FC-85FC-1BB12F6359AD.jpeg 165DCED7-6DB1-454E-92E9-C41804518479.jpeg Got alignment done and exhaust installed today sounds good. 3106C9CD-30F8-455B-B147-935A133E303C.jpeg 01FEDA0F-0D91-4344-B0E0-81E91B67A887.jpeg
    Perkolator and Erwin Merida like this.
  19. Roland Deschain
    Did a drain and fill on both front and rear differentials this past weekend. 06182E89-FDFC-4AF1-8714-BF53D3C58942.jpeg
  20. Roland Deschain
    New door seals arrived today I had no idea when I ordered them they were actually OE Toyota.
