My 1972 Gen2 build
Discussion in 'Pre-1975 Build-Up/Project Threads' started by jetas, Jan 11, 2016.
  1. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    You have a 1 or 2 piece drive shaft?
  2. jetas
    1 piece. Been throwing the idea around about a 2 piece since this crap started
  3. Erwin Merida
    Raise the rear end and throw it in gear. No road nosie, maybe you can pin point it better.. or a lift.
    Ive used jacks stands to simulate some load. Does it get louder with speed or pedal input?
    jetas likes this.
  4. jetas
    Done that a few times already. Just hard figure it out in the garage solo.
  5. jetas
    Not sure when the last time i complained about my no start when hot issue with this damn truck. Well i decided to try to replace one of the few things i hadnt swapped out yet which was the starter.
    Got AC Delco unit in from Rockauto, To my surprise its MUCH smaller and cranks way faster. So far I haven't had the slow crank when hot and its fired up perfectly a few times after simulating conditions. Time will tell.
    also rewired my electric fan to a thermo switch from the adjustable probe thing i had. Wasnt consistent and the engine temp would go past 210° at times even with the fan on.
    Erwin Merida likes this.
  6. Erwin Merida
    Hope that was it. No/slow starts are a bitch to have in the back of your head while driving.. lol would give me anxiety!
    Are you using a shroud on your rad?
    jetas likes this.
  7. jetas
    Yea, i havent been driving it as much as i used to since this crap started, which started after i bagged it sadly.
    And yes, factory shroud but i have the E-fan mounted to the Rad with those stupid pull thru ziptie type things. Probably not funneling the heat out very well
  8. Erwin Merida
    I had a magazine with page on a shop the did custom aluminum shrouds to fit. I hate that I can't find it.. I need to update my entire cooling system. Thanks to a lot of info on this forum that you guys share, I'm planning wisely.
  9. jetas
    Honestly doesnt look very hard to make a shroud. Ive been very tempted to make my own shroud
  10. Erwin Merida
    True, a couple bends and a couple of a holes.lol
    Btw, how's the heat shield working after about a year?
  11. jetas
    The heat shield stuff has been fine. Only problem is they smell kinda funky, almost like a pizza smell
  12. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    If you got your hands on a plasma cutter it shouldn't be to bad to make. A long bar fold will do you well to.
    jetas likes this.
  13. Erwin Merida
    @Pearce I'd love to fab it myself, just don't have the equipment.
    @jetas that's oddly random, and hilarious! Haha hey, as long as it does it's intended job.
    jetas likes this.
  14. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    You don't always need a lot of equipment. You can definitely do a big hole with a cut off wheel on a grinder. Just easier to mess up. A bar fold is a super simple tool that can can be made out of pieces of metal and vise grips if need be. Usually better then one you would buy because you can size it for whatever you need.
  15. jetas
    Shit a jigsaw with the right blade might even do the trick lol
  16. Erwin Merida
    That's true, gota be creative!
    jetas likes this.
  17. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    A design I've seen for optimum performance you might want to look at doing is a few vents around the perimeter with rubber flaps on the outside. This way you have more area to push air through when driving without the fan. When the fan is running it pulls them shut.
    Erwin Merida and jetas like this.
  18. jetas
    Got any pics of that?
  19. Erwin Merida
    That sound ingenious. But wouldn't the rubber dry and crack due to heat exposure?
  20. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
