My 1972 Gen2 build
Discussion in 'Pre-1975 Build-Up/Project Threads' started by jetas, Jan 11, 2016.
  1. jetas
    Small update. Got the battery checked yesterday and its good. So it made me think of wtf else could be the issue. Decided to check the air gap on the pick up coil in the distributor. To my surprise the little tab on the pick up looks like it was not cut straight and the gap on all but one spot was massive. Filed it flat, regapped it and the bitch fired right up.
    had my wife check it this morning when it was colder, fired up first try. So i think i may have fixed my starting problem. Time will tell
    RN23CB likes this.
  2. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Niiiice! Congrats man
  3. jetas
    Thanks man. I was already looking to see what engines i could pick up and swap for cheap but this small fix has put me back on track
  4. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Nice! I would've kicked myself in the head if I swapped the engine, when all I had to do was file the points even.. hahaha mannnn, good save!!
    jetas likes this.
  5. jetas
    Dude trust me i went over this damn thing and tried so much shit before coming to this. I knew i was something simple just had to figure out what it was
  6. Erwin Merida
    Perseverance is key! Btw, did you re check the timing?
  7. jetas
    Yup. Still at 8°
    Erwin Merida likes this.
  8. Erwin Merida
    I'm starting to wonder why/how this issue started. Hopefully they were just loose and mis aligned, which got corrected when you filed and reset. Temp does play a small part in conductivity and I think you were at the brink of that spectrum.. hope this issue doesn't come back.
  9. jetas
    It must have been the shitty quality of the thai repop i bought that i didnt notice when i first installed it.
    i honestly do think the lower temps we've had here in the morning may have played a part in it but i doubt its anything that wasnt taken into account when the truck was engineered. 40° Temps aint that bad
  10. Erwin Merida
    True that. These things are over engineered.
  11. jetas
    Not sure wtf is going on with my truck but nit didnt start this morning AGAIN. I will say that the one thing all my starting issues have had in common in the MSD box and my distributor. So in the spirit of trying something else I ordered a Pertronix Ignitor to replace the pick up coil and MSD box at the same time.
    idk if its going to help or not but im doing it anyway and hope it works. Il post the MSD box for sale soon of anyone is interested
  12. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Is you dizzy points?
  13. jetas
    Electronic.
  14. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    I'm not sure pertronix will work. A points dizzy has lobes on the shaft that opens the points. The little pickup ring you get with the pertronix sets in place by the lobes.
  15. jetas
    Shit were guna learn here pretty soon lol. The 20R/22R dizzy has rectangular tabs coming off the shaft.
    RN23CB and Erwin Merida like this.
  16. Erwin Merida
    I'm looking to adopt a coil on plug thru a wasted spark system.. NODIZ Pro.. and do away with the dizzy on my 22re.
  17. jetas
    Considered that, more than im wanting to spend on this
  18. Erwin Merida
    Haha. Yea ignition systems can get pricey quick! I planing on keeping tht setup under $500 from coil to ecm. But then, tuning will be limitless. To a certain degree..lol
  19. jetas
    I figure when i decide to spend a bunch of $ on a engine it will be for a swap
  20. Erwin Merida
    See that's also true asf! Can't beat $261 for an engine at the pick-ur-part! Hahah
