My 1972 Gen2 build
Discussion in 'Pre-1975 Build-Up/Project Threads' started by jetas, Jan 11, 2016.
  1. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Sparkly :applause:
    jetas likes this.
  2. KS.ID
    KS.ID Enthusiast
    Bay Area, CA
    RN22 1972 Hilux
    Whoa! Didn't see that coming! I'm curious to see the end result when you replace the plastic bits!
    I've had the idea of having the knobs for the headlights/hazards machined out of metal! Something like this would be pretty neat.
    jetas and 74RN22 like this.
  3. jetas
    You and me both. Im going to attack it this weekend and hopefully get it all put back together and cleaned up. As far as the knobs go, i actually want to get some laminated teardrop knobs. Gotta find someone who makes them, i dont really care for the ones mooneyes has.
  4. jetas
    took 2 weekends but the rear is done, still need to mount the air management, wire, plumb and then attack the front. Still not sure what il be doing for the bed floor but for now its got a giant hole.
  5. KS.ID
    KS.ID Enthusiast
    Bay Area, CA
    RN22 1972 Hilux
    Full Send!! Is that a first gen I see in the driveway?
    jetas likes this.
  6. jetas
    Lol. And no its my friends Datsun 521
  7. Collin Ramos
    Collin Ramos Member
    So I’m in the process of installing my hub but once the hub makes contact with the column you horn goes off. Why is that?
  8. jetas
    On mine if i remember right i had to adjust the contact on the column. Honestly cant remember tho. Its been a while
  9. jetas
    Alright so i havent updated this since the whole "Safer at home" order went into place in Cali. But ive been slowly chugging away on the front suspension, focusing on the driver side. Heres some of the progress
    Front end stripped, hood has been pulled off since this pic
    Spring pockets chopped out and bag brackets welded in. Dominator 2500 bags. And yes ive cleaned up a lot of the crud thats on the control arms, shit was nasty.
    Now at that point i was able to get the wheel to tuck up about this much, still needed another 4" to be at the height that the bottom of the frame was at.
    then i studied a few other peoples builds and decided to mod the LCA balljoint mount. Practiced on a spare control arm i have was able to raise the BJ 1.5" from the factory point. Still need to fishplate and reinforce it. I also had to pie cut the UCA to keep the upper BJ From binding up so quickly, yes it sacrificed lift BUT i really dont need too much. I didnt take a pic of what i did but heres an example I used to mod mine.
    Heres a shot before the control arm mods
    Hers the after. It tucked up over 2" more
    This is pretty much where im at now. Im waiting on some lower shock bushing replacements so i can finish the shock relocation. Got to finish weld everything that isnt done yet and plate up a few spots. After that il be moving on to the passenger side and replicating everything. After that il be on to the next stage which will be Z'ing the front clip to get the frame to lay completely flat and dealing with whatever challenges that brings me.
  10. KS.ID
    KS.ID Enthusiast
    Bay Area, CA
    RN22 1972 Hilux
    WOW! Great progress!
    What's your at home welding set up? I'm looking to buy something soon.
  11. jetas
    Thanks man.
    im running a Lincoln 140 with C25 shielding gas now. Good set up to start with, prep and practice will do your projects a lot of good
  12. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Welds look pretty good. Will definitely hold up.
  13. jetas
    Not all of them came out pretty but theyre plenty fckin strong
  14. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Cant really expect them all to unless you're a master. Even then its hard to get right. Especially with different joints styles.
    I'm sure the bad ones look better then anybody's welds that said mig is easy.
  15. jetas
    Shit no kidding, theres some odd angles ive had to deal with and those i need to touch up
  16. jetas
    Small update. Got the truck on the ground a while back. Its actually back on jackstands now to pull the engine for the Z.
    Theres still sunlight visible Between chassis and ground. Its resting on the leaf spring hangars and the front subframe. Thats all getting addressed soon
    Perkolator likes this.
  17. redman
    redman Enthusiast
    Southcentral PA.
    Lookin Good.:waytogo:
    jetas likes this.
  18. jetas
    Thanks man
  19. jetas
    A little more progress, got the engine and trans pulled yesterday. Going to take some time to clean the engine bay as well as the engine and trans before i start cutting the frame. Il be changing out some seals while im at it. Valve cover has been leaking all over the fckin place so thats first up. Il probably rework my trans crossmember AGAIN while its out too.
    RN23CB likes this.
  20. 74RN22
    74RN22 Enthusiast
    Warner Robins, Georgia
    1974 RN22 Hilux
    That truck is so low it's dragging on a red ants back... That is tight to the ground, outstanding!!!
    Which transmission is that?
    jetas likes this.
