My 1972 Gen2 build
Discussion in 'Pre-1975 Build-Up/Project Threads' started by jetas, Jan 11, 2016.
  1. phlpdvs
    phlpdvs Newbie
    Atlanta
    1977 Toyota pickup
    I had an issue similar with a '74 Plymouth and it turned out to be a balast resister for the coil. I know some old Toyotas have these things. I think I have one on my '77 but not sure if you would on a '72. It's usually a pretty cheap part.
  2. jetas
    I actually havent had a ballast resistor on this truck at all and its ran fine. Spoke with a MSD rep and they gave me a few things to try. Im guna try to mess with it again tonight
  3. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    You wouldn't want one on the msd anyway. Quicker coil failure may result with the stock system but you would get a hotter spark.
  4. jetas
    After messing with this damn thing for a month it FINALLY FIRED UP!
    I pulled 22R dizzy and swapped the new pickup coil to the 20R dizzy i had removed a while back and stabbed that bitch in the motor and after moving it a bit it turned right on like nothing ever happened.
    Heres a little snippet
    74RN22 and Pearce like this.
  5. 74RN22
    74RN22 Enthusiast
    Warner Robins, Georgia
    1974 RN22 Hilux
    See I knew you would figure this out. now you will be able to test that 22RC distributor and find out where the failure point is so that you and correct it and have a usable spare.
    it was not something as simple as the ground wire from the plate to the side of that distributor was it?
    jetas likes this.
  6. jetas
    Didnt get much time to mess with it other than what i did. But im definitely going to look into refreshing the 22R dizzy
    74RN22 likes this.
  7. jetas
    Alright so i have the truck at a point where it will start and run. Hit it with the timing light and the Timing mark on the crank pulley is way off to the left, not sure if thats advanced or retarted, anyway, i think it may be because the vacumm advance may be stuck in a advanced position.
    now i just need to remount the MSD box and il be able to drive it again. Il definitely be taking it out this weekend at some point to see what it does
    Heres a couple pics
    74RN22 likes this.
  8. jetas
    Took the truck to work today and i have to say something still isnt right. Pretty sure its a carb issue, cold start aint right. Guna try to mess with it this weekend.
  9. 74RN22
    74RN22 Enthusiast
    1974 RN22 Hilux
    So you did finally get the timing set correctly?
    Incorrect timing will affect it and the issue will seem like a fuel issue. Make sure that no water is in the bottom of your float bowl of your carburetor.
  10. jetas
    @74RN22 The timing seems like its still a little off but i think it may be due to the vacumm advance on the dizzy not functioning properly.
    i actually messed with it a little yesterday then cruised around with some friends and made some more adjustments and it seems to be running better. Choke still needs a bit more tweaking to get the cold start right.
    Dan McBoost and 74RN22 like this.
  11. 1975 hilux stok
    1975 hilux stok Newbie
    hey, guys I just got my first car or truck it's a 1975 Toyota Hilux with a carburated 20r motor. any mods you guys would recommend.
  12. 74RN22
    74RN22 Enthusiast
    1974 RN22 Hilux
    1975 hilux stok and Pearce like this.
  13. 1975 hilux stok
    nice man, does anyone recommend any carbs
  14. 1975 hilux stok
  15. 1975 hilux stok
    also does anybody know where to get a damn chin lip for my truck
  16. 1975 hilux stok
    something like this
  17. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    I would start your own build thread. This is someone else's and not a general thread.
  18. jetas
    Finally purchased some new shocks for the front of the truck. The shocks that were in it were trashed when I put them in. Theyre cheapies from rockauto, didnt wana spend too much since i know they're guna get blown out away... theyre almost completely compressed. The front end feels so much better! Used to have that old cadillac floatiness up front.
    Lower mounts on the old shocks were bent. I know i had lost one of the bolts on the freeway a few weeks back. Not sure why the other tab is bent
    Perkolator and 74RN22 like this.
  19. jetas
    Took this one yesterday during my lunch hour
    74RN22 likes this.
  20. jetas
    this was yesterday at and on my way back from cars and coffee. The Datsun is my friends truck
    74RN22 likes this.
