Metal brake line fail.
Discussion in 'Engine/Drivetrain' started by fred heath, Dec 3, 2019.
  1. fred heath
    fred heath Addict
    Raleigh, NC
    Thought I’d throw this out there for consideration.
    I suddenly had my brake pedal go soft while driving. Pulled over and checked the front reservoir found it almost empty. Checked all the fittings, could find no leaks. Got it home and started really looking.
    On my 1978, the metal line that services the front left caliper passes under the inner fender drivers side. Apparently, over time the abrasive action actually cut into the metal line causing it to fail. Replaced with the new style copper(can be bent by hand) which is DOPE. Rerouted it away from the inner fender. Up and running.
  2. jetas
    Wow thats a terrible spot for that line. Glad the situation wasnt worse!
  3. fred heath
    fred heath Addict
    Raleigh, NC
    Weird thing is it’s factory original. Line & location. Could be over time the inner fender dropped a little causing the wear. I relocated the new line away from the fender.
  4. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Oh wow. I noticed my hard lines were really close to touching that same spot too. Gonna learn from your situation and bend the inner fender back a little bit now.
    fred heath likes this.
  5. jetas
    This makes me happy that i redid al my brake lines
  6. Henry
    Henry Enthusiast
    Washington State
    Guess I need to take a look at mine. Thanks for the heads up
