Lowering Truck Norris
Discussion in '1984-1988 Build-Up/Project Threads' started by SteveWippins, Jan 22, 2024.
  1. SteveWippins
    SteveWippins Enthusiast
    1988 base model
    Currently in the process of lowering my 88 base model, the GF called it Truck Norris and the name stuck because I've used and abused this thing for 12 years and it refuses to die. Anyways, I'm replacing the ball joints(upper and lower) and installing Belltech 2" drop spindles and Nitro Drop 2 shocks along with 3" blocks for the rear. Thought i would share a few photos of the process so far.
    Perkolator and Erwin Merida like this.
  2. SteveWippins
    1988 base model
    NAPA brand ball joints in case anyone was wondering
  3. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    That's going to ride nice. Someone else is experiencing issues with this same setup.. positive camber I believe.. all info is welcome.
  4. RetirementToy
    RetirementToy Member
    Vallejo,CA
    1988 Toyota Extra Cab 2WD
    Close to what I did when I started my build with bagging it in the plan, I used dropped rear leafs along with angle blocks.
    This lead to installing the 8 piece rear notch ahead of schedule ,as the third member was hitting the frame!
  5. SteveWippins
    1988 base model
    Positive camber huh? that's odd. the only other thing i've ever lowered was a 350z and ended up with negative camber.
  6. SteveWippins
    1988 base model
    The front is done and put back together. Went ahead and put new rear seals in the hubs as well. I'll be test fitting the 14s in a little while.
  7. SteveWippins
    1988 base model
  8. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    The issue pops up if you get wide wheels that still tuck in, inside the fenders. Because your wheels' offset is so low, or even negative (?), you won't have any clearance issues.
    Either the lower ball joint or lower arm, and, I believe the brake backing plate, will contact the wheel if it has a lot of backspacing.
  9. SteveWippins
    1988 base model
    that makes perfect sense. I can definitely see the lowers being a potential issue.
  10. RetirementToy
    Vallejo,CA
    If you never go with larger brakes you will need to go with a larger dia. wheel.
    And with that the wheel will hit the inner fender & limit travel & causing tie rod damage!!
  11. SteveWippins
    1988 base model
    I don't see myself using bigger brakes, not like this thing can go fast anyways.
    BRASS MONKEY likes this.
  12. SteveWippins
    1988 base model
  13. SteveWippins
    1988 base model
    Just dropped it off for a front end alignment :headbang:
    Going to give it a well deserved wash afterwards and hopefully do a little cruising today. I haven't been this excited about a vehicle in a long time and it's SUCH a good feeling.
    RetirementToy and Erwin Merida like this.
  14. Erwin Merida
    That's what's all about! Enjoy it.
    SteveWippins and RetirementToy like this.
  15. SteveWippins
    1988 base model
    I'm definitely enjoying it!! I washed it after the alignment was done, and i've driven it work the past 2 days. Reached out to someone about welding up some seat brackets for the 1st gen MR2 seats i've had forever, so hopefully that will be getting done soon.
  16. SteveWippins
    1988 base model
    Once the new seats are in, maybe even before that, I'm thinking about tinting the windows. I have a 96 tacoma 4x4 with tint, and honestly like the difference it makes in hot weather. Also currently in the market for new wheels. I found a set of Appliance Diamags but they sold before i could get to them.
    Erwin Merida likes this.
  17. Erwin Merida
    Definitely keep us posted on those MR2 seats. I have some. Others have wondered as well. I know our trucks differ from Gen to Gen but still the same concept.
    SteveWippins likes this.
  18. Erwin Merida
    Those wheels are nice. Not surprised someone snatched em up quick!!
  19. SteveWippins
    1988 base model
    I'll definitely keep the thread updated. Supposed to be meeting up with a guy this week for a quote. The seats i have are black/blue and still have the sliders on them. I'm also not surprised the wheels sold quickly, just wish i could've been there sooner! Oh well
  20. SteveWippins
    1988 base model
    I'm about to go look at some 14x7 "aluminum slot mags" as the guy calls them. I have a feeling i'll end up purchasing them. Will post pics later on today.
