KYNgsx's '89
Discussion in '1989-1995 Build-Up/Project Threads' started by KYNgsx, Oct 28, 2009.
  1. 93xtracab
    93xtracab Newbie
    Hey nice truck love the color and the weld wheels. I wanted to know how you flipped your balljoints when you lowered it? I want to lower mine more but don't want to have bad camber...
  2. IronNam
    Welcome! make a intro thread sometime whenever you're open. its nice to see a fellow xcab.
    Here's some pics of a flipped B/j
    what you basically accomplish is placing the spindle above the arms.
  3. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    Cleaned up the motor today and did a quick polish of the valve cover:
    I need get the correct water pump and a gasket for the egr blockoff plate at the back of the head. After that I just need to wait for my clutch and flywheel to come in and then it's ready to go. :)
  4. 89dlx47
    89dlx47 Veteran
    st. louis
    89 standard 2wd
    man i love the look of the old valve covers over the new ones. motor looks great man!
  5. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    Swapped in the new motor today. Only got a couple pictures since I got really dirty. Did a lot of cleaning until I ran out of Simple Green. It also took a little longer than usual because I had to swap oil pans and pickup tubes between the two motors (2wd vs. 4wd). I found pretty much a whole set of plastic timing chain guides in the oil pan of the motor that came out of my truck, as well as some random bits of metal that I could not identify. :doah:
    p.s. I know I forgot the dust shield in the pictures, it's on now. :p
    LC 9lb billet aluminum flywheel
    I can't remember where I had heard of the trick to get the pilot bearing out using grease and a punch, but I tried it and it worked. :waytogo:
    LC pro clutch kit
    I had to put the truck on the ramps because the front wheels of my engine hoist couldn't fit under my crossmemeber.:D
    The engine is all bolted in place right now so all the hard work is done. I stopped working because it was getting a little too late to use air tools. All I need to do now is bolt up the manifolds and radiator and go get some fluids. I should have more pictures tomorrow.
  6. TOY|STORY808
    TOY|STORY808 Enthusiast
    WAIPAHU TO LAS VEGAS
    1985 TOYOTA PICK UP
    nice build...
    cant wait to hear what it sounds like
    what part of hawaii you from???
  7. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    I can't wait to hear it also. My other motor sounded pretty nuts already. :)
    I'm on Kauai.
  8. IronNam
    so low he cant swap motors x D
  9. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    Got everything back together and started it up yesterday.
    Kinda looks the same as before, just a little bit cleaner. I do see some dirty spots I missed though. :rolleyes: Before I bolted the exhaust back up I got a quick video clip, but I'm having trouble logging in to Youtube and uploading the video. I'll try again later. This motor revs really fast, especially with the light flywheel. I just need to adjust valves, carbs, and timing and then it's good to go.
  10. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    nice job man....... just curious but where did you hook up your vaccume adv/ret from your dist?
  11. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    Thanks. How's your truck coming along? There is a small vacuum port on the #1 intake runner for the distributor advance.
  12. TRfknD
    TRfknD Veteran
    The Woodlands, TX via (Guahan)
    96 Taco / 05 Tundra
    Very nice build!!! I'm digging it! :cool:
  13. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    ^ That's nice to hear, especially from a guy with a super clean turbo tacoma. Thanks! :)
  14. IronNam
    im jealous of your motor :]
  15. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    Got a new toy to play with. :)
    Sample video:
    Low quality so it would upload faster. I accidently turned the camera off on my first run so I only have this short clip. I was mostly just trying to get a feel for how the camera worked anyway. I'll try and get more footage later.
  16. IronNam
    GoPro cams ftw!
    those lens are nice on those small cameras, its amazing how they can capture alot!
    the wide captures more than what my camera can (24mm lawl)
  17. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    MY PRIDE MY JOY MY TOY!
    wow, your motor setup is sickk. do you already have gearings?
  18. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    sweet camera rig. its gorgeous over there. and you shift like its a diesel compared to how i drive mine. lol. i need to do a camera rig and make some videos.
  19. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    Gearing is stock. I shift when the belt squeaks, lol. I have an electric fan I need to swap in later.
  20. IronNam
    Lol, I hope you intend to make a write up DIY for the fans too!
