Itschrisb’s ‘86 Daily build
Discussion in '1984-1988 Build-Up/Project Threads' started by itschrisb, Mar 12, 2021.
  1. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Hell yea, patience is key! Show it some love, and it'll love you back!! Hahah
    itschrisb likes this.
  2. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
  3. itschrisb
    itschrisb Newbie
    thanks for the link, how was the fit?
    I should have the last of the parts to finish up the carb swap this week. I also got the remainder of the exterior parts I was waiting on so I’m really looking forward to finishing it all up.
    I wanted to see what people’s opinions on a 5 speed swap is? Finding 5 speed 2wd transmissions around me isn’t easy or cheap so just curious if it’s worth the time and effort. And if it is which 5 speed would be my best bet?
  4. Erwin Merida
    Are you going to tow anything?
  5. itschrisb
    itschrisb Newbie
    I really don’t think I’ll ever tow anything with it.
  6. Erwin Merida
    Get the w55/w56. If you want shorter 1st and 2nd, then go for a later model w56.
  7. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    The only fitment issue was one of the bolts on the steering box was rubbing so I flipped it, otherwise good to go.
  8. itschrisb
    itschrisb Newbie
    I’ve been slowly working on it when I have had time. I got it all back together and did get it to run with the Weber carb but soon found a few coolant leaks so I’m in the middle of fixing that.
    another issue the truck has had since purchasing was the blower motor didn’t work, found it to be a bad resistor, but the more another part is none of the HVAC controls move. I’m not sure if the cables are stuck or the actual mechanism they turn. I really don’t want to pull the dash apart to find out.
    scratch that I figured out why nothing would move, it’s all packed full of mouse houses! I pulled the blower motor and found this.
    FBDB13AB-B9E3-46F5-923B-1FE4E2F06D50.jpeg Looks like I may have to pull the dash to clean to all out after all. Unless someone could give me a tip on removing the HVAC stuff otherwise.
    also in the process of tearing it all apart I found this what looks to be original brown vinyl under the outdoor carpet someone laid down.
    Also if anyone were to have HVAC controls for a pickup with AC they’re looking to part with mines all messed up!
  9. itschrisb
    itschrisb Newbie
    A little before and after of the engine bay. It could definitely still use some tidying up but man does it feel good to be where it’s at now.
    I also picked up this ‘74 Yamaha DT250 as a new summer project. Fits well with the Toyota.
    At this point I need to continue cleaning out the HVAC system. Otherwise I wanna lower it. As long as these wheels clear the drop spindles I’m going to keep them and put a larger tire on the rear to give me some more highway speed back.
    Vellu, Erwin Merida and jetas like this.
  10. itschrisb
    itschrisb Newbie
    Not a whole lot to update but I installed a Holley fuel pressure regulator, sorted out my fuel line issues and through on a front breather from K&N. Now I have proper pressure for the Weber and the gas tank is venting properly. Truck is running mint now.
    This truck has come along way from the old dirty beater work truck it was when I first got it.
    It’s amazing what a few cosmetic changes really does.
    Erwin Merida likes this.
  11. Erwin Merida
    Seams like you're starting to fall in lovvveeee! Hahaha keep it up, hard work always pays off!
  12. itschrisb
    itschrisb Newbie
    yeah it’s growing on me for sure. It’s fun bringing something back to life. I realize I’m not doing anything someone else hasn’t done before but it keeps me busy.
    People running Webers, what’s your timing set at?
  13. itschrisb
    itschrisb Newbie
    Removed the old mouse infested brown house carpet and scrubbed the interior today. Very pleased with the results.
    I wish these seats weren’t so beat up because they’re comfortable. Anyone have any idea if these are stock or from another vehicle?
    51707457-CC54-4D75-BFFE-E0213BB2964C.jpeg DEF927B6-BCD4-4F67-B73A-93CCEECAE61D.jpeg
  14. Erwin Merida
    Those look like 4runner seats.. from a 5th gen.
  15. Erwin Merida
    Actually I take that back... Those look more Euro!
