irs swap from mklll...coilover questions
Discussion in 'Suspension/Chassis' started by hardlux, Sep 29, 2013.
  1. hardlux
    hardlux Member
    :looney:
  2. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
  3. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    If you look up how the Corvettes suspension works then you would under stand what i mean
    its just idea I have to save bed space if i ever do the swap
    ps to this very day the Corvette still runs leaf springs
  4. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Sort of. Yes the corvette still runs leaf suspension but it has been a single slab of fiberglass not an off the shelf leaf pack like most would think of when that is suggested.
  5. NashMan
    NashMan Toyotaholic
    94 2wd
    Could be off the self just have to find one that will work
  6. Robert m
    Robert m Addict
    Apple Valley, Ca
    or, you make it easier and run coilovers
  7. NashMan
    NashMan Toyotaholic
    94 2wd
    I have dirt bike i like to haul around so makes it tougher for me
  8. Robert m
    Robert m Addict
    Apple Valley, Ca
    Then it sounds like an IRS swap probably isnt the route to go.
  9. rabbit.arrow
    rabbit.arrow Member
    AZ
    1986 carb shortbed Pickup
    I have thought about the C5 Corvette and my '77 Longbed...the suspension would allow lots of low, but with travel and bed retention! They have almost the same wheelbase, so I thought Corvette underneath and Lucy on top. But retain the complete Corvette underpinnings you WOULD have to cut up the body to get low...but the motor and suspension (minus the torque tube for moar low) under a ToyotaMini would be the tits! Check this truck out! Cool story! <--Just like that but Toyota bed floor retention (this is the biggest hurdle) and moar lowerer!
  10. rabbit.arrow
    rabbit.arrow Member
    AZ
    I think the leaf idea is rad! I think bed cutting is-what-it-is...but stock appearance is so cool when low! And a bed is why I bought a truck...I think with something like corvette rear suspension is just the right answer, and I think that with the right setup you could still haul...albeit not a ton, but maybe close to a 1/2 ton.
  11. yotaman95
    yotaman95 Enthusiast
    Cottonwood Heights Utah
    1995 single cab
    You drive one nasty truck my friend keep it up!!!
  12. Dcups
    Dcups Addict
    Seattle
    93 Std Cab chassis/4Runner 2door body
    How's the truck coming along.
    Ever think of swapping in the Supra IFS as well?
    With the IRS. The track width is different front to rear and the wheels will. Look weird IMHO.
  13. hardlux
    hardlux Member
    I'm running wheel spacers up front. The rear was only approx 1.5" wider.
  14. 87driftyota
    87driftyota Newbie
    Hey man that front setup is sick I like the brackets you made. You said that you re enforced it. Do you have pics of the front end finished with the bracing?
  15. Dcups
    Dcups Addict
    Seattle
    Any pics of the truck in action or better yet a vid? Hows it handling?
  16. hardlux
    hardlux Member
    Before they were cleaned up and painted.
  17. hardlux
    hardlux Member
    I'm still building the truck. :shrug:
  18. 87driftyota
    87driftyota Newbie
    Just curious what tubular a-arms are you using?
  19. hardlux
    hardlux Member
    Kbs fabrications...formally cando. Very nice arms.
  20. 87driftyota
    87driftyota Newbie
    Also when you ordered the qa1's, you ordered the bearing mount and not the poly mount correct?
