irs swap from mklll...coilover questions
Discussion in 'Suspension/Chassis' started by hardlux, Sep 29, 2013.
  1. hardlux
    hardlux Member
    exactly!
  2. hardlux
    hardlux Member
    cool man thanks
  3. 87driftyota
    87driftyota Newbie
    Do you have the front coilovers mounted with some pics?
  4. BatryOpratedBoy
    BatryOpratedBoy Enthusiast
    Fresno. =(
    Brave Little Toaster (Diana) and Salsa Verde (Traction Control)
    I don't have anything to contribute, but...
  5. hardlux
    hardlux Member
    Front coilovers and 7m turbo Ill be swapping in as well
  6. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    may want to make you coil mount a wee bit stronger
  7. L3GACY
    L3GACY Enthusiast
    Knoxville, TN
    1993 ExCab
    That engine is beautiful looking...wish I had more faith in myself to completely tear mine apart and make it look as clean as that.
  8. hardlux
    hardlux Member
    That's a old pic of the coilovers... mounts are braced now.
  9. REDZ
    REDZ Enthusiast
    what did u do re the gas tank
  10. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    Thank you so much for the step-by-step pictures of the IRS install. I'm definitely saving those.
  11. hardlux
    hardlux Member
    Your welcome. And for the fuel tank..I'm running a 17 gal rci behind the irs
  12. AIRICK
    AIRICK Enthusiast
    Northern KY/ Cincinnati Area
    83 Standard Pickup
    I'm amazed at that IRS swap and I can't stop looking at all the pics. I can't believe I've never seen that on here before.
    I've got a whole IRS out of a turbo Supra and I might have give this a try on my 83. I was just going to swap the 3rd member into a V6 8" rearend and leave it at that.
    Thanks for the inspiration; I hope it all works out for. I can't wait to see it with the bed on there.
  13. hardlux
    hardlux Member
    Page 4 #37
  14. hardlux
    hardlux Member
    Just about done with the rear. Just need some lower arms and some paint.
  15. AIRICK
    AIRICK Enthusiast
    83 Standard Pickup
    Sorry, I missed that one.
    Looks good.
  16. rabbit.arrow
    rabbit.arrow Member
    AZ
    1986 carb shortbed Pickup
    Too good!:jawdrop::jawdrop: I am blown away by the apparent simplicity! Now you gotta cut the bed up more thought...Best full coilover/IRS I've seen on a non- full tube frame truck!:bow::bow::bow::bow: (and your trying to retain the bed floor:waytogo::waytogo:)
  17. hardlux
    hardlux Member
    I made it so the bars unbolt, so the bed floor is still intact. just need to unbolt the bars to remove/install the bed. Or I can remove the bars if I need to haul something as well.
  18. NashMan
    NashMan Toyotaholic
    94 2wd
    Why not run a leaf pack thou ????
  19. hardlux
    hardlux Member
    Leafsprings?
  20. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    He speaks in riddles sometimes. :lol:
    I'm guessing he means running leaf springs laterally like in an older corvette but I could of course be way wrong. :ROFL:
