irs swap from mklll...coilover questions
Discussion in 'Suspension/Chassis' started by hardlux, Sep 29, 2013.
  1. hardlux
    hardlux Member
    more
  2. hardlux
    hardlux Member
    and more...
  3. hardlux
    hardlux Member
  4. hardlux
    hardlux Member
    Finished
  5. hardlux
    hardlux Member
    4 wheel camber achieved
  6. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    That's badass! Thanks for posting so many. I saved them all to reference.
    Does the front mount of the subframe hang below truck frame rail height? How much camber does it have at ride height? Do you plan to swap the various control arms with any aftermarket ones, and if so, what's the good ones to get? Other than further requiring me to make fender flares, this looks like something I could tackle on a weekend with a welder. Very informative. Thanks again.
    And do you have any plans sorted out for how to mount the strut out back? A small hoop would work well or to stay under the bed I was thinking you could run off the corner of the frame to a lower arm, if there's one strong enough to take the load.
    Also, with it set to your proper wheelbase, did your driveline length work out the same or did that have to be changed? What about the ebrake cables? Thanks again.
  7. standardbyker88
    lynnwood, wa
    Does a sway bar work its way into that mix at all? Is it even needed? I'm seriously debating this after your build pics confirmed the step by step process I already assumed you took for most of it. Great work.
  8. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    that looks like it sit's rather high and the upper a arm is rather jacked
    your going to need custom lower arms made up
  9. hardlux
    hardlux Member
    The front mounts do hang slightly below the frame, I debated notching the frame to recess them, but that would have gave it too much pinion angel. The mounts actually attach just beyond where the frame starts to slope up, so they only hang down just barely, and since tuckin 20's or laying frame isnt the plan, its no problem at all. Its amazing how everything dam near fell into place, the slope of the frame just about matches the slope of the irs cage.
    Cambers no issue as the rear is adjustable. No need to change control arms as well.
    Mounting the qa1's is next, the shock length at ride height is approx. 12", and will require the wheel wells be opened up to clear the coilovers/mounts. I think structurally the best bet is to use the factory spindle mounts and run a hoop like you stated.
    Once the suspension is done, my next step is swapping in the 7m. Driveline will definitely need to be shortened.Ebrake cables not a problem either, thats the beauty about the toyotas, they used alot of the same ideas between all theyre models making interchanging parts a breeze.
  10. hardlux
    hardlux Member
    Theres already a factory sway bar mounted and the aftermarket parts available for the mkIII's make the possibilities endless.
    Thanks man, its not a tough swap, just ALOT of measuring. Once you knock all the leafspring mounts off the frame, you can jack the assembly up to the frame and use a big ratchet strap to secure the front of it. This will give you some play to move things around as needed to get the measurements you need.
  11. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    I've got 3 different width 8" axles I've been collecting so I have the correct one for my new build. Now I'm seeing how easy it is to swap in IRS and here I am building an autocross truck where this is ideal... Damnit now I need to find a wrecked supra. :D
  12. standardbyker88
    lynnwood, wa
    You find a good supra to test drive and ill wreck it. We can split the parts :lol:
  13. NashMan
    NashMan Toyotaholic
    94 2wd
    I own a mk3 supra with the stock cams adjusters I run out adjustment
    and I have far less upper a arm angle
    you can buy them thou to fix the alignment
    all so the stock sub bushings are rather ****ty I just run alum spacer the stock sub frame moves around alot thats one reason why they tend to crack
  14. hardlux
    hardlux Member
    Where do you get these aluminum spacers you speak of nash?
  15. hardlux
    hardlux Member
    So just an update... beds back on and with 245/45/17's on 17x7x39 rims, no rub at all..Actually could go a little wider.
  16. L3GACY
    L3GACY Enthusiast
    Knoxville, TN
    1993 ExCab
    Shouldn't have opened up this thread...Now I want to go and find a MKIII rear end and do this with my truck. I'm going to save all this info you have gotten up for a later date. Still need to drop the 7mgte in that I picked up before even thinking about this. Love the work that you did on yours and its very inspirational!
  17. hardlux
    hardlux Member
    Thanks man, that means alot. If you do decide to do it, let me know. I still have all the templates and I'll help you any way possible! I attatched a pic of the coilovers installed, I was still able to retain the stock bed floor.
  18. White Trash
    Eastern WA
    I think I finally talked myself into doing the irs swap. A local supra guy is sourcing a rear subframe and knuckles out for me now. :D
    whats the specs on the wheels to get them to clear the body?
  19. standardbyker88
    lynnwood, wa
    He said 17x7x39 so I took it as a 17x7" with +39mm offset.
    Love it. Looks great together. Nobody except the rare few will notice from the bed floor.
  20. NashMan
    NashMan Toyotaholic
    94 2wd
    I Just made them but you can buy them from ronick he sell's polly replacement ones
