Idle surging when braking ?
Discussion in 'Engine/Drivetrain' started by Gsalvob3, Mar 26, 2017.
  1. Gsalvob3
    Gsalvob3 Member
    Charlottesville Virginia
    1994 Toyota pickup ext cab
    Anyone got any ideas as to why my idle rpms drop when I apply the brakes is it my iacv or throttle body or low coolant a vacuum leak or just a combination of things I need some help any info would be great
  2. Gsalvob3
    Gsalvob3 Member
    The engine has cut off before from applying the brakes too hard
  3. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    I'm not sure, but just a guess might be the vacuum line from the brake booster to the intake manifold?
  4. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    Isn't there supposed to be a check valve on that line?
  5. jetas
    Yea there is
  6. Tuhd The Troll
    Houston, TX
    1982 SR5
    Then it's probably stuck and needs cleaned out
  7. jetas
    Could be missing all together, dude doesnt seem to be checking in anyway
  8. Gsalvob3
    Gsalvob3 Member
    I messed with the idle bolt a little and raised the idle slightly.. It seems to be working ok for now but my idle screw bolt attached to the throttle body seems very loose is everyone's like that.. Cause I feel like with the engine vibration it could move on its own
  9. Gsalvob3
    Gsalvob3 Member
    how can you tell wether your truck is at the right idle rpms when my trucks doesn't have an rpm gage tachometer
  10. Gsalvob3
    Gsalvob3 Member
    Isn't a 22re suppose to be at idle at around 750 rpms for normal running conditions/warmed up
