Idle issues when breaking
Discussion in 'Engine/Drivetrain' started by Tattedfordguy, Dec 31, 2014.
  1. Tattedfordguy
    Tattedfordguy Enthusiast
    IE
    92 single cab toyota
    When I step on the breaks for any amount of time the idle starts jumping up and down has anyone had this problem? What do I need to do to fix this!
  2. jetas
    Vaccum leak?
  3. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Yup, either the booster is bad or the vacuum line between the booster and intake is split somewhere.
  4. jetas
    Replace the vaccum to the booster. Its cheap and easy.
  5. Tattedfordguy
    IE
    Can you post a pic of the part
  6. jetas
    The hose coming off of the brake booster. (Not my engine bay BTW)
  7. Tattedfordguy
    IE
    Thank you
  8. Tattedfordguy
    IE
    I took it to a shop and they told me it's the part circled, the shop quoted 190 for part
  9. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    The afm? No. They are wrong.
  10. jetas
    Thats what im saying
  11. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    do this. its the simplest easiest fix. if still having issues, most likely its in the booster.
  12. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Sounds more like your idle is set too high. When you apply the brakes the ecu thinks your coming to a stop so it kills the injectors to save fuel. The shops guess at the AFM is the reason for my diagnosis... Base idle is 750-800 rpms, 900-1k with AC on...
    My experience with boosters is a hard pedal feel prior to any idle fluctuation. Good luck!
  13. Malandrin4o8
    Malandrin4o8 Newbie
    Had a similar problem, mine was idle screw came loose on tb turned it down and it stopped it. Might want to check screw.
  14. Xs5875
    Xs5875 Addict
    Greenville, Ga
    oh, and its OCD, but this is a huge problem..the title of this thread.
    Your truck has BRAKES. Not BREAKS. You take a break, you use the brakes to stop your truck. Not the other way around....
    ok, rant over.
  15. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    rotflmfao!!
  16. White Trash
    Eastern WA
    You're right about the idle setting causing the surge too. It's been so long since I dinked with an re I'd forgotten that cause. I've had booster vacuum lines and a vacuum check valve go bad once and the only symptom was rpm surge under braking. It doesn't take much of a leak to cause it.
  17. Tattedfordguy
    IE
    Ha ha, I must have been typing fast and tired sence I work nights...
  18. myles66
    myles66 Newbie
    little rock, AR
    1990 toyota hilux 2x4
    i had to replace my afm, the electrical chip in it goes out... but you wouldnt be able to keep it running if the afm is out, or at least i wasnt, or anyone else that ive heard of. definitely a vacuum leak and a garage thatll clean up your afm (call it refurbished) and replace youre hose without you being the wiser. or at least thats a what someone as paranoid as me would think...
