How to rattle can paint wheels.
Discussion in 'Wheels/Tires' started by confused.rat, Jan 21, 2012.
  1. confused.rat
    confused.rat Enthusiast
    Springdale, Ar
    1993 Pickup Ext Cab.
    So I bought a new set of wheels for the Yota this week. 15"x7" Cragar Smoothies. Great wheels. Only I didn't like all the "bling", so I decided to paint the center of the wheels black to give it a more "old school" look. Here is how i did it.
    Supplies:
    Wheels (DUH!)
    Masking Tape
    220 Grit Sandpaper
    Masking Paper
    Rattle Can Primer
    Rattle Can Paint
    Rattle Can Clear Coat.
    Rubbing Alcohol
    Paper Towels
    LOTS OF TIME!
    Sexy "Smooth" Smoothies.
    Before Paint.
    I started by going ahead and taping the wheels off. Using 2"-3" strips of tape will make it easier to get into the corners of the wheels.
    Start applying the masking paper. I cut the paper into about 4"x6" squares. This made it easier to curl the the paper over the wheel so you could tape it down.
    My helpers.
    All done with the taping process.
    Now I sanded the wheels using 3M 220 Wetordry sandpaper. Get comfortable, cause you're going to be here a while.
    After about a little more than a hour of sanding im finally done.
    I used some of the masking paper and taped it to the floor of my garage to help with over spray.
    Using the rubbing alcohol and a paper towel wipe down the wheels to remove any dirt or oil from your hands.
    Now the moment has come that you can paint. Primer first though.
    I put 3 layers of primer, 5 layers of paint, and 4 layers of clear coat. Waiting about 15-20 minutes between coats.
    I forgot to take pics of the wheels while I applied the black paint. But this is how they look on the truck.
    And my reward.
  2. moonbeam
    moonbeam Member
    Marietta, Ga.
    94 std cab 2X4
    Great job, wheels look nice rewards look better! :)
  3. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Nice job bro. Looks good
  4. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    looking good!! im really liking that style of wheel! looks good man
  5. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    That was a great write up!!! Very helpful tips!!!
  6. confused.rat
    Springdale, Ar
    thanks guys. i really like hoe they turned out.
  7. randy20r
    randy20r Member
    georgia
    1976 toyota pickup
    nice job
  8. crashburnoveride
    crashburnoveride Member
    Lincoln, NE
    88 reg cab pickup
  9. luke gtr
    luke gtr Newbie
    sydney
    1968 rn10
    good job.
    thanks for the write up.
