How To Do A Ball Joint Flip (by SD Yota)
Discussion in 'Suspension/Chassis' started by SD YOTA, Mar 22, 2010.
  1. Grizz806
    Grizz806 Member
    Boondocks,Lubbock, Tx
    1987 2wd
    Just wanted to drop in and say, I reeaally apreciated this spep by step instructions, I hope to be seing more people do this, it helps everone out.
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    i think i need to see a writeup on the hilux trucks. but great job buddy. i would do this to my hilux, but i dont think i have any more available drop before im sitting the crossmember on the ground hahaha. but if i tear into the front, ill deffinately check it out and see if it would help. the rear is my issue more so. but i will try my swap bar back in there to see how it fits since i cant remember.
    anyways, nice job!
  3. smartmonkey
    smartmonkey Veteran
    Australia
    v320, 620, 720KC, RN46, LN46, YN65 & B2200
    Thats is easy as changing a tyre... Talk about simple.
    Nice work on the thread, straight to the point.
    Tom.
  4. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    do you have to do uppers and lowers?? Or can u just do the lowers???
  5. standardbyker88
    lynnwood, wa
    Most guys seem to just do the lowers.
  6. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    thanks for the compliments guys.
    the uppers do not need to be done. our trucks unlike the later tacoma trucks do not have the camber issue when dropped so the uppers dont need to be relocated. :waytogo:
  7. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    cool! Thx for the write up man!
  8. chrisyou
    chrisyou Member
    Bay Area, CA.
    1993 2wd std. cab
    thanks for the tutorial!
  9. dwnshfter
    dwnshfter Member
    I'll be doing this once I get my DS in :) Any reason I should not?
  10. SD YOTA
    your welcome guys. glad it helps.
    dwn- DS? :shrug:
    there's not really a reason not to do it unless you dont wanna go low i......? :shrug:
  11. standardbyker88
    lynnwood, wa
    drop shocks? dip ****? down syndrome? i dont know. just lower it :ROFL:
  12. SD YOTA
    :lol: :ROFL:
    come to think of it you could say your truck and mine have a severe case of "down" syndrome :evil:
  13. standardbyker88
    lynnwood, wa
    Well yeah, yours does look like it has a birth defect with all the different colors of skin tone. And that front lip that droops over its chin. My truck doesn't look like a crack baby. HAHAHAHA :ROFL::funnyup:
  14. IronNam
    holy batman, no one told me he put a tutorial up here!
    I said I would but never did.....
    anyway, props for the details. Hope others will look through this. I had too much explaining around here
  15. SD YOTA
    very fitting since my crack baby will inflict some serious ownage on your gimp of a fossil ass draggin granny truck when i crack the throttle open :ROFL:
    shall we? :evil: :lol:
    yea i get it, my truck needs to get done..... ive been hearin allot about it lately trust me :rolleyes:
  16. Toyota530
    Toyota530 Veteran
    94 toy xcab
    :ROFL::ROFL::funnyup::funnyup::lol: Mine is just like yours SD YOTA!! Work needs to be done ;)
  17. IronNam
    lol loving this thread.
    btw SDYOTA, good thing you pointed out to flip that bracket. I figured that out when i did mine.
    One thing i didn't do is the spacer/washers
  18. SD YOTA
    yea........ keep in mind that when you add a couple spacers or washers into the b/j flip to maximize the effect there.... that is less torsion you have to uncrank in order to drop it and keeps a better spring rate for the drop!
    the actual AIM behind the b/j flip lies more in keeping your torsion rate up as close to stock as possible so you DONT end up with a spongey, soggy wet bread feel type ride to your front suspension. if you gain a 1 1/2 worth of drop in the flip, then its 1 1/2 inch less you gotta take out from the torsions in order to achieve a 3/3 or 4/3 drop.
    one thing to also keep in mind with all 84-94 trucks.......... your rear fender bottom lines sit 1 inche lower than your front fender bottom lines. so in most cases if you want to keep an "even" look to your truck, you will typically want to drop your truck an inch lower in the front. yes........ this will give you some slight rake but damn near unoticeable since the truck will look like its stitting evenly across the fender lines with your tires. :waytogo:
  19. dwnshfter
    dwnshfter Member
    DS= drop spindles ;) and mine just got dropped off by UPS 30 seconds ago!!!!
  20. HALMS
    HALMS Enthusiast
    Guam
    93 reg. cab, 95 reg. cab
    Hella Props on the write up, I just have one question. I seem to know the pros of the flip, but are there any cons on this procedure, any incident of breakage. thanx
