how much to put on a 3body lift
Discussion in '1984-1988 Build-Up/Project Threads' started by xNOOKX, Apr 6, 2009.
  1. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    oh yeah but for a real, cheap lift, crank your torsion bars up and flip your axle and get lift blocks for the rear...
  2. 88Sandshark
    88Sandshark Toyotaholic
    Lake Elsinore, CA
    Very simple stuff to do as far as I'm told, nearly every Toyota 4x4 owner I know has done this.
  3. fourwd1
    fourwd1 Member
    central MD
    84 4Runner rock crawler
    Cranking the t-bars will increase your ride height, but you loose the same amount of travel in the opposite direction (you can't get something for nothing). Also, the ride will be harsher.
    "flip your axle" ???? now that's the dumbest thing I ever heard. :eek:
    Not only will the R&P gears and bearings not get properly lubricated, you will have 1 forward gear and 5 reverse, and you will be driving on the coast (weaker) side of the gears.
    It would be much more sense and be a LOT easier to just weld new perches on top of the axle. :rolleyes:
    And get some ball joint spacers for the front.
  4. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    Body lifts are pretty easy to do yourself and only make the truck taller. You don't gain ground clearence or width. A shop would probably sell you the kit and install it for around $800. suspension lifts are deffinately the way to go fro off roading though. Or if you don't want the noticable gap between your frame and body.
  5. fourwd1
    fourwd1 Member
    central MD
    $800 ??
    If it takes a shop 10 hrs to install a BL you need to find another shop.
  6. V8_TITAN
    Tampa Fl
    89 std cab
    your not actually flipping your axle, you place the springs on top of the axle vs having them under it...
  7. Predracer
    Conyers, GA
    Yeah the shops around here are ridiculous, thats why I do everything myself
  8. Sam78
    Sam78 Enthusiast
    Oceanside
    78 toyota longbed 5speed 20R
    :clapping:
    just buy a 4x4 and go have some (useful) fun instead of raising it and
    not eing able to do anything with it
  9. phil03
    phil03 Enthusiast
    ottawa,canada
    93 pick-up
    just do the lift on your truck, fit some 235-75r15 toyo open country......go have some fun, my 2wd takes me wherever i want to go!!!....no need for a 4x4 unless you sell your 2wd...this trend is just going back and forth!
    Do what you want to do with your truck, you CAN do it yourself(the body lift)
  10. xNOOKX
    xNOOKX Member
    Arkansas
    1987 toyota pickup
    how much would it cost 2 do a 3inch suspension lift
