well been trying to fix up my truck and get it running good, today it decides to get a mid rpm rod knock, which sucks cause i havent had this truck 3 weeks. whats worse is i have a 180k good 22re laying around but its for this so what im probally going to end up doing is taking the 311,000 mile engine from the celica and putting a timing chain assembly in it along with rebuilding the bottom end, and throw it in my truck also im going to get dual chrome mirrors, replace the carpet, add other lil creature comforts such as a clock, sr5 cluster, hvac panel, a decent system setup, sound deadining and 85 celica gts seats or 4 runner seats. as for other things i plan to do is get a decent cam and either a weber 34/34 or a 38/38, im leaning more towards the 38 due to the extra 90 cfm and this truck wont be my daily this what this is for. and the other thing on my list is to get the rear 2 rims fixed, the rear wheels seem to have a small crack which lets the tires go flat every 3 days. good thing i have the stock steelies laying around. this is gonna be interesting.
thanks, yeah i like to keep things simple to work on called the machine shop today, they quoted me 325 to get the short block rebuilt if i bring my own kit, i may go this route. ive priced a good rebuild kit from enginebuilder at 220 dollars. ill get the head checked out and decked , im weary of the head cause it had some narly vavle noise. ill update as i go along
he told me 325 if i bring my own kit and thats for the short block im debating buying new or used head due to the one on the truck is seeping oil hey shonuff im the same guy on the gts boards, in fact u told me about this site awhile ago
a broken cell phone, 2 fishing rods 1 reel and 45 dollars later new head with some work done to it, wrist pin noise this lil gem will be sent to the machine shop.
took a trip to see buddy in mobile al to get my trans for my celica. while i was there i too a junkyard trip and got a clock, cig lighter assembly, driver vent, and some other interior goodies, best of all i scored 2 sr5 clusters im in the process of waiting for a seller to put up clear corners for 40 shipped on ebay,and a already have a pair of chrome mirrors. i adjusted the vavles and the truck ran like a scaled ape, as he was beating metal with a hammer. so yes it does knock but now know where the lack of power was comming from. i know fix then engine get rolling again but im also gathering parts while they are cheap or when i can find them.
july 17 update well heres an update ive aquired a 150k engine thats still good, if the timing chain hasnt been done, ill take the time and do it, but if it has ill just change the seals and gaskets on it and put it in the truck. so i should be mobile by the middle of next month if all goes as planned oh ill have a nice lil stereo set up as well
its a budget build but should sound good when finished, im still trying to find a really good but cheap hu on craigslist (i got an alpine for 40 dollars for my other ride) the doors will have , for now some xplode 3 or 4 way 6x9s on the doors, i havent looked at them in 2 months, some infinity kappa 4s with a built in bass adjustment (i can have bass running to them or just highs or adjust the bass) a 8 inch non amped bazooka tube between the bucket seats which i may fab a console around. and i have 2 4 challen amps laying around. 1 is a 50x4 rms alpine the other is a 300 rms kenwood amp. i may just use 1 though, im trying to make a good compact system without building speaker kick panels or sacrificing leg room for a sub box due to my long legs.
Can I make a couple suggestions? First, I would just use a nice set of 6 1/2" components in the doors. I think they sound WAY better than 6x9's. This is what I have: Alpine's Type-S 6 1/2" component set with a 3/4" mdf spacer (to clear the window) wrapped in grey suede. They are running off the head unit (for now) and sound great. I paid like $100 for 'em. Second, watch out using the Infinity Kappa's. They used to be a 2 ohm speaker. You cannot run a 2 ohm speaker off of a head unit, they are designed to run 4 ohm speakers only. You can run them off an amp no problem.
i may take your advice on them one thing to remember is i have all this stuff laying around already heres how my last 87 looked withe the 6x9s on the doors, didnt even cut the doors other thing to consider is im freshening up my donor motor so ill have to hold off on non drivetrain related purchases for now
donor engine is on the stand, awaiting timing chain job. I plan to do it the right way so im going to get the head cleaned and checked along with new vavle stem seals. I might order a cam for the truck next week or 2 as well. I have a timing chain set with a new oil pump and cover i won 3 weeks ago for 50 shipped, guess ill use it. Also i just ordered a topline brand headgasket set with bolts on sale for 52 dollars shipped. today i plan to clean the engine, and dissassemble the head. Ill also paint the valve cover as well.
damn im slowly making headway, tore down doner motor, should be back togather within 2-3 weeks NICE LIL UPDATE ON PARTS: so i bought this for 400 dollars: rest can be seen here http://s127.photobucket.com/albums/p158/Joe_1985/86%20turbo%20sr5%20rust%20runner/ 22rte is going in my celica no ifs ands or buts about it, the interior on the other hand, is going in my truck, plus i like the old schoolness of this truck and rather use the 32/36 i have sitting in a box, a trd stage 1 cam, and the celica's header. the digi dash does work but i dunno if ill swap it or just sell it, prob sell it cause i like analog guages. The seats dunno, i need a whole mechanical assembly for the passenger side, the adjuster for the rails are missing and cables are broke. The carpet, i may cleanup and sell, i already installed new carpet in my truck. The inclometer, its spoken for. The power doors, i plan to put on the truck one day but will need new motors, current ones work but are slow as hell. carpeted kickpanels im using, im going to try to use the floor shifter assembly. pretty much im gutting the interior of the 4 runner using what i can and selling the rest, dont worry ill make a forsale thread. i also may use the exaust if its not rotted, i saw it was replaced at one point in time. My current exaust is aftermarket but sounds like ass and is poorly welded. also ill pull the whole body front end, if i dont use the parts ill post em up for sale as well.
didnt give up, ive just been trying to finish my 22rte for my 85 celica and small stuff on my beater keeps breaking/wearing out. but heres what i have collected long round magnaflow truck muffler today im supposed to get a set of sr5 carpeted window crank style panels (going to hold off from the p/w conversion for now.) 2 sets of header factory rain visors for the doors complete w/accessories 135k 85 celica 22re for 200 bucks, going to use this engine alpine 250 watt amp 99-04 mustang 16s w/o the ford logo wrapped in 205/50/15s (18s are bent and cracked) and a factory floor shifter assembly from a base 84 2wd, never seen that before also i have a sr5 cluster somewhere, i just have to find it next on the list of stuff is: new front bumper and valance red/white tails kickdown cable rear bumper clear turns
