help to lower my toy
Discussion in 'Suspension/Chassis' started by joekiyu, May 10, 2011.
  1. joekiyu
    joekiyu Newbie
    1089 22R pickup
    now if i can get a write up in how to do the torstion and how to add drop blocks ill be all set~
  2. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    Drop blocks are self explanitory... 8 bolts and your done,make sure the pins are all lined up. Torsion bars are a matter of loosening a bolt while holding a jam nut and taking a few measurments... If it doesent come easily to you, you should have somebody else do it for you. Just my .02 Where are you located?
  3. jetas
    Lift rear of truck. Support on jacksands. Remove shocks from lower shock plate. Loosen both nuts on each U bolt. Raise axle with jack. Put blocks between axle and leaf springs. Put in new U bolts and just do everything in reverse.
  4. joekiyu
    joekiyu Newbie
    1089 22R pickup
    i just got to ask just to be in the safe side. but yeah sounds simple and i am out in sant clara ca
  5. jetas
    Dam so many So Cal guys on here but no one is less than an hour from me
  6. silos92
    silos92 Member
    savannah, ga
    1992 hilux
    Lol there a lot closer to you then me, I'm all the way in Georgia
  7. jetas
    Lol. Sadly il be the odd one driving a dam nissan.
