Help fuel problem
Discussion in '1989-1995 Pickup Discussion' started by Stephen Lloyd, Jun 11, 2018.
  1. Stephen Lloyd
    Stephen Lloyd Newbie
    So I have a 94 Toyota pickup 2wd 22re with 253000 miles and here recently I've noticed a strong fuel smell in and around the cab and it takes alot longer than usual to start it just dosent fire up like it used to any input would be appreciated
  2. Clay
    Clay Member
    Ohio
    93 Pickup
    a fuel smell in the cab would imply a leak somewhere. maybe a line is rotted or unplugged? like on the canister? though if it's affecting the performance I would look around the fuel rail. like a bad o-ring seal around an injector. the fuel filter is bolted to the passenger side of the engine block under the intake manifold. could check there too.
  3. Stephen Lloyd
    What does the canister look like
  4. Clay
    Clay Member
    Ohio
    93 Pickup
  5. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Check the start injector at the fuel rail. it has two copper washers ,one on each side & it threads into the rail.
    If it has been removed new washers must be used!
