Fuel Sending Unit
Discussion in 'Maintenance/Repair' started by Perkolator, May 24, 2016.
  1. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Who's got info on fuel sending units for the 73-78 Hilux? Are there any replacements available?
    My truck's fuel gauge decided to stop working the other day. Assume the culprit is the fuel sending unit but haven't yet had time to look into it. I know I read some stuff about severed wires to the unit and some people reporting a fracture/separation in the "coil" that it uses to determine level. If it's the wire, I can fix that. Guessing fixing the broken coil isn't as simple as welding/brazing it together since it deals with resistance - so wondering if there are any outright replacements available? I haven't found anything yet - can one from a newer Toyota be used?
  2. jetas
    There are some repops in ebay of the sending unit and actual gauge assembly
  3. Perkolator
    Placer County
    1975 Hilux
    Holy cow I had no idea. Less than $30 shipped! In reading up on this problem I saw someone paid around $150 to have a company fix a stock unit, just a few years ago.
    Before I buy one, does anyone have experience with one of these? I assume if it's listed for our trucks it should fit and work flawlessly, but just want to make sure the Ohm range is correct and not just a "universal" part.
  4. jetas
    You may have to be the guinea pig bro
  5. Perkolator
    Placer County
    1975 Hilux
    What's your take on this? I was searching info on this fuel sending unit and came up with a posting here on TM from 2010 by priusjames (http://toyotaminis.com/forum/threads/fs-fuel-sending-unit-for-rn20-brand-new-in-box.5901/) Said he had a new fuel sender but it didn't fit his RN23 truck, which is what mine is too. I did read on all those eBay specials that they mention RN20 and RN25, but no RN23 mentioned. Saw another thread and it looks like priusjames bought the same one? http://toyotaminis.com/forum/threads/wtb-fuel-tank-float-sending-unit-75-hilux.5741/
    new part: http://www.ebay.com/itm/TOYOTA-PICK...ash=item3d1b363eb2:g:NQMAAOSwq5pXQear&vxp=mtr
  6. jetas
    Its probably meant for an early truck with a mechanical pump. Mine looks like that, originally had a 18R.
    Its gotta be different on the 75+ trucks because of the electric in tank pump.
  7. Perkolator
    Placer County
    1975 Hilux
    ...so you think the eBay one is for a 72-74 truck, not the 75-78?
    I sent the seller an inquiry, hopefully they are knowledgeable.
  8. jetas
    Thats going to be my best guess.
  9. Perkolator
    Placer County
    1975 Hilux
    So now my fuel gauge is working again....my guess at this point is sticky float maybe.
  10. fred heath
    fred heath Addict
    Raleigh, NC
    You may have a bad ground wire at the tank.
    Some senders have a separate ground wire
    Usually when a sender goes bad you will get an inaccurate gage reading. i.e. 3/4 tank when you know its full. Or you'll suddenly see the gage dropping as your driving. Scares the s**t out of you. You think you just ruptured the tank..
