Frostop Dialy
Discussion in '1984-1988 Build-Up/Project Threads' started by Frostop, Jun 16, 2023.
  1. Frostop
    Frostop Member
    Baton Rouge
    87 2wd auto Xtra cab long bed
  2. Frostop
    Frostop Member
    Baton Rouge
    One month of testing and a few loose ends later it's back to daily driver reliability. Handles amazing. No body roll what so ever. 1500lbs in the bed and it starts to ride comfortably. No weight and it'll hurt your back. The 410 gears made it a lot peppier too.
  3. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Hey!
    I just noticed...
    Is that a front bumper.bolted on to tge front bumper but upside down?
    That actually looks pretty good. What a fun idea...
  4. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    YOOOOO I just saw that upside down mod!! Good way to be original!! It does look pretty good!! Almost looks like a great place to put an intercooler if your were running boost!!
    As for the ride quality, I'm guessing you added the 1 ton leafs?? Honestly, that's why I like the shorter wheel base. Our tires actually absorb a lot of the initial impacts when going down the road, so twice the tires will stiffen things up a bit.. glad to see it back on the road!
  5. Erwin Merida
    Also noticed you went from 5 to 6 lug, was that a simple spindle swap? Did you have to swap the idler arm and brakes too?
  6. Frostop
    Frostop Member
    Baton Rouge
    The front is the one ton torsions, calipers with brackets, rotors, hubs and sway bar. All of which was a direct bolt on with no modifications needed. Everything else is exactly the same.
    Erwin Merida likes this.
  7. Frostop
    Frostop Member
    Baton Rouge
    The rear springs required welding the front spring hanger brackets from the RV. The e-brake cables also had to be shortened. I also had to order custom u-bolts for the 3 inch blocks and larger leafs.
  8. Erwin Merida
    Dang that's good info. Even for someone tryna do the opposite and go from 6 to 5 for more wheel options. :waytogo:
  9. Frostop
    Frostop Member
    Baton Rouge
