Finally its going somewhere
Discussion in 'Suspension/Chassis' started by Dgerfan55, May 7, 2010.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I got mine from lowes it's a Lincoln mig 180 it was like $750 about $250 cheaper than my local welding supply. It's a 220 volt an I use argon mix an I've welded 1/4" no problem
  2. IronNam
    Hell yeah, no fluxcore okay?
  3. jyaortead
    jyaortead Enthusiast
    SC
    Get a millermatic 180, .30 wire, bottle of unimix, and get after it.:waytogo:
  4. DROPT
    DROPT Addict
    Whales Vagina
    get a hobart 187
  5. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Whats better stick or feeder
  6. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Stick you weld till the stick is gone then stop change the stick and continue on
    Wire feed you weld till your finished.
    Whats your definition of better?
  7. flg8r22
    flg8r22 Enthusiast
    Orlando Florida
    81 4x4, 83 4x4, 86 4x4
    stick welding is good for really heavy welding. for thinner stuff 1/4 inch and under, i like the miller-matic, lays down some sweet welds!
  8. Dgerfan55
    lake elsinore CA
    94 pickup
    Something that is going to hold and strongest. I used to use a stick welder when i work at heavy equipment rental yard. So i know there strong if done right but was just wondering about the wire. Never welded on a truck so thats why i ask the best.
  9. oahu grown
    Hawaii
    92 Extra Cab
    With wire you get more flexibility i would say. If your looking for penetration, heat is the answer and a bigger welder will allow you to do that in my opinion.
  10. IronNam
    Wire has a smaller contact point, so it'll strike an arc easier.
    220V stick likes big metal :D
  11. Dgerfan55
    lake elsinore CA
    94 pickup
    What from a 1987 supra can work on my truck? Engine wise?
  12. IronNam
    theoretically the VAFM could work.
    Grab the injectors? i guess you could save em for later, some other project, or sell em off :D
    the whole engine?
  13. Dgerfan55
    lake elsinore CA
    94 pickup
    K cool thanks CINN. Whats a better welder, I have a choice from a LINCOLN ac-225 arc welder-- This one is stick, or a LINCOLN pro core 125, pro core 140 or a pro core 180. These ones are wire fed. So what one is good enough to work on our trucks?
  14. jyaortead
    SC
    say no to flux core. solid wire and sheilding gas ftw.
  15. Dgerfan55
    lake elsinore CA
    94 pickup
    Why is that ?
  16. IronNam
    You don't want to find out.
  17. Dgerfan55
    lake elsinore CA
    94 pickup
    So will the 125 work good? i know the more the better but money is still tight?
  18. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    The 125 will be good for body work...that's about it.
  19. Dgerfan55
    lake elsinore CA
    94 pickup
    What wont i be able to do with it? Just want to make sure its the right one for me.
  20. jyaortead
    SC
    Alright, I own a millermatic 180 with autoset, with an aluminum spool gun, and a cart. I found it on the web, cant remember the site, for 1000 bucks to my door.
    It will weld anything, its 230 vac, if I only had 115, I'd go with the millermatic 140, those little machines will still weld thick stuff, 1/4 in, great if, IF, you preheat with a torch.
    If you must have a red machine go with the lincoln power mig 180, for 230, or power mig 140, 120.
    If you need something a little cheaper go with the lincoln SP-180T or SP-140T.
    These two dont have infinite adjustments, that just means you can fine tune it for that perfect bead.
    If you still don't want to spend that much, then there's really no need to purchase a lesser machine, because with flux core, the welds will look like tin man siht, and you'll get discouraged and you will no longer have a desire to weld. Then you'll never learn to weld.
    Exaggerating just a little, but only a little.
