fiberglass guy , building a 84 .
Discussion in '1984-1988 Build-Up/Project Threads' started by slacker, Sep 9, 2007.
  1. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    me 4!
  2. slacker
    slacker Addict
    Penticton BC , Canada
    84-7m-GTE custom
    thanks fellas ..
    slow but sure .. I'm workin'
  3. slacker
    slacker Addict
    84-7m-GTE custom
    so over the last week , I have been building my repair panels and today I was able to get them burnt in , rears as well
    now with the rockers repaired , I was able to get the cab height finalized @ 9" from the rockers to the Ground . + I also started on the cab mounts
    Because there are only going to be 4 mounts instead of 6 , I wanted to make sure there were going to be strong .
    cut out some 3/16" plate and surrounded it with some tube
    Tacked into place I will add some more supports later , when I turn the frame over .
    1 more front frame mount tomorrow , then I can get on the front cab mount
  4. slacker
    slacker Addict
    84-7m-GTE custom
    and cab side mount
    Bent up some 1/2" solid stock with the 3/16" plate . as well as a "fish plate" for the cab side , 1/2" stock actually goes threw the fish plate for a stronger "plug" weld , and a toyota stock body mount bushing , I now have the front mounted
    and now the front of the cab is mounted
    still have some supports and final welding to do when I can turn over the frame , but for now it's good to go
    also .. the cab now has it final "stance"
    acetone can for referance ....
  5. slacker
    slacker Addict
    84-7m-GTE custom
    got to work today making the rear cab mounts
    as with the fronts .. plug welded
    and yeah!!! , cab is no mounted to the frame
  6. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    MY PRIDE MY JOY MY TOY!
  7. MattMcCarthy
    MattMcCarthy Veteran
    Monterey, CA
    89 2jz
    When you get done with this build we got to meet up! I want to see this thing in person! I just wish I had the time and money to go to coil-overs on my truck but being in the military stops me there. And I need to learn more fab skills.
    My truck under the Knife right now for the fuel system. but can not wait to get my baby back and get it tuned.
  8. slacker
    slacker Addict
    84-7m-GTE custom
    cool .. there are much easier ways to do it then what I'm doing . The aftermarket has way smaller/shorter coil overs that would make things much easier .. easy is not my plan though as I want to utalize some of the "functions" of the factory supra
    keep watch , and hopefully , with the pics .. it will help , and one day you can do it yourself
  9. slacker
    slacker Addict
    84-7m-GTE custom
    finally got my tube contour guage , so I was able to find some time this afternoon to "fit" the front suspension .
    tacked , and jack stands kicked out
  10. IronNam
    Very beautiful slacker, nice to see it's coming together!
    as for the front fenders, since you wanted to run those wheels, how about remold the fenders to slightly angle that way it'll keep the same look and still let the wheels and tires go in if they need to?
  11. slacker
    slacker Addict
    84-7m-GTE custom
    I am going to replace tires and wheels .. so I can always change backspacing .. wheel travel shouldnt be a problem . What I want is the FATEST tire I can possably fit under there
  12. slacker
    slacker Addict
    84-7m-GTE custom
    trimmed up some glass pieces today ..
    time to start on the flip front
  13. Dcups
    Dcups Addict
    Seattle
    93 Std Cab chassis/4Runner 2door body
    Man that looks good.... Any thoughts on shorting up the xtra cab window? So the bottom of the glass is lined up even with the door glass. I never thought they flowed well from factory.
  14. slacker
    slacker Addict
    84-7m-GTE custom
    thanks .. and yes .. I have been "thinking" of the best to deal with this . I was going to make that window power , up and down , like the fronts .. but I may run in to some issues with the suiside door hinges .. I know this dosnt address the "style' .. but I think it would be just pure cool !!
    + it'll match the rear power 4runner window i'm going to do in the rear :)
    still have to decide if i'm going to "chop" the top .. have to decide this soon
    OR
    a complete , removable hard top type conversion
  15. robhojy
    robhojy Newbie
    essex,UK
    1991 toyota hilux pickup, singlecab 2wd petrol
    this is an awesome build, definatly subscribed :)
    im also loving the 7mgte enthuiasiam you have, i did the exact same thing, bin the mk3 supra and put the 7mgte into a pickup, although i havnt gone independant,
    il be watching this closely,
    and definatly cant wait to see the power window.
  16. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    nice work man!
    glad to see the 84 getting its turn in the shop :)
  17. Dcups
    Dcups Addict
    Seattle
    I vote ALL of the above!!!! Or the Targa top from the Supra keep the theme going...
  18. CrazyCody93
    CrazyCody93 Enthusiast
    Gresham OR
    84 Sr5 Xtra cab
    I sure do like this truck, i cant wait to see what it looks like when your done!
  19. slacker
    slacker Addict
    84-7m-GTE custom
    thanks fellas ..
    work on this has been slow on my truck as my shop is packed with customer units :) ..
    I have been working on the flip front thought . Did some work on the hood and fenders .. also finally got it on the dollies , so now I can move it around the shop , which will really help
  20. CrazyCody93
    Gresham OR
    84 Sr5 Xtra cab
    Well hopefully your makin money faster then you can spend it!
