Fans, reservoirs, and a few others.
Discussion in 'For Sale' started by Justin Danger, Nov 22, 2018.
  1. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Hi, I was cleaning out my shed in preparation for some upcoming engine work, and came a cross a few extra bits that I would like to offer to you folks.
    First off is an Aisin fan and clutch, the stock system off of my 86 22rte. I went to electric a while back, there is nothing wrong (that i know of) with this unit. 25$ plush shipping if needed.
    Second is the first E-Fan that I used until I got a radiator with an integrated fan and shroud. It is a Hayden 3700-04 16" spiral fan. Again, nothing wrong with it, just have no use for it. 35$ plush shipping if needed.
    Thirdly are a pair of reservoirs, one for coolant and one for washer fluid. I've gone with billet reservoirs and have no use for these. I took a rag to them, but didn't try tok hard, they will probably clean up nice nice if you wanted. They are the original NipponDenso ones from my 86 pickup. 25$ each plush shipping if needed.
    Washer Fluid:
  2. Justin Danger
    Bay Area Peninsula
    Coolant Reservoir:
    20181122_195508.jpg 20181122_195520.jpg 20181122_195530.jpg 20181122_195558.jpg
    Next up is a pair of aluminum drop blocks. They are 2" tapered aluminum blocks. I used these for a little bit before I installed drop leafs. They are in nice condition. I am selling them without the u bolts. 25$ for the pair.
  3. Justin Danger
    Bay Area Peninsula
    And I have the Belltech Nitro Drop shocks that I used Before I went to the Monroes that I now run. I modified a tab on the lower mounts to allow the shock to easily be installed (otherwise it is too wide to fit through the control arm). They still absorb on compression and rebound, and were nice shocks when I had them on. 30$ for the pair.
    I also have a pair of the Gabriel rear coilover shocks that I can provide pictures of. 30$ for them. I also have some miscellaneous things like a visor, center console, ceiling light, those brackets for your spare tire to rest up on, etc.... again I can provide pictures if anyone is interested.
  4. Justin Danger
    Bay Area Peninsula
    I am building a new motor, so I just wanted to add to this list the block, head, pistons, alternator, and a bunch of other stuff from my old motor. Inquire for picture and details.
    cheers
