Fake Dually Wheel Spacers
Discussion in 'Wheels/Tires' started by Olds77421, May 29, 2023.
  1. Olds77421
    Olds77421 Member
    Illinois
    1976 Toyota Chinook
    I checked and confirmed that the truck does in fact have the G082 rear end which means the 3/4 ton 8".
    Not really all that excited about the prospect of hunting down a 1 ton diff, as they're hard to find and expensive and the single wheel without offset looks super wimpy.
    Guess I'll start looking into custom builds, unless anyone has any more thoughts or options. Appreciate the input from everyone.
  2. fred heath
    fred heath Addict
    Raleigh, NC
    You’re light enough to go single tire (that’s what I did). I found an early GM truck axle to be a perfect fit and restore the rear track to the same width as the foolie. It’s not a cheap upgrade($4K est.) but is perfect for this application. See attached build thread.
    https://toyotamotorhome.org/forums/...wap-foolie-to-1-ton-full-float/#comment-72800
  3. blackmedal1942
    blackmedal1942 Member
    WA
    1978 Toyota Galavan
    Great info in this thread, thanks Fred. I've got a '78 Galavan with single wheel and am looking to fill out the fender a bit too with offset/spacer + wider wheels + tires. It sounds like you're saying that can cause the same type of stress on the shafts that the foolie does. Is that correct Fred?
  4. fred heath
    fred heath Addict
    Raleigh, NC
    That’s correct. Your Galavan originally came with foolies. Someone must of changed to singles at some point. You could add a sway bar for stability, but I wouldn’t extend from zero offset to be safe. This will center the weight where it needs to be. I’ve attached some information about the Galavan that I’ve acquired over time. There are only a handful of these toys left in operation.
  5. blackmedal1942
    WA
    1978 Toyota Galavan
    I believe it came from the factory with singles. She's a 16 footer. I can upload more images if it helps.
    Good to know. Will prob just keep it safe and not extend it.
  6. fred heath
    fred heath Addict
    Raleigh, NC
    They’re all 16’. Is that foil label a Toyota label or a Champion label? If Champion, it did come with single wheels.
    You’re lucky if it did. You don’t want to change anything.
  7. blackmedal1942
    WA
    1978 Toyota Galavan
    Yeah it's a Champion. Looks like Toyota built the chassis in March of 78 and Champion finished the build in July.
  8. fred heath
    fred heath Addict
    Raleigh, NC
    They were only built for two years. 1978/79. The ‘78 has the porthole glass in the back and smaller side windows. My 1979 has no porthole windows and larger side windows (see profile picture). They’re great little rigs.
  9. blackmedal1942
    WA
    1978 Toyota Galavan
    Love what you've done with it. Saw your post on toyotamotorhome covering the GM rear axle swap. Tempting now that I don't have any "safe" ways to fill out the huge gap of not having dualies Not only cosmetic, but would love to beef up the tread and stability with some wider wheels + tires.
