Hello, all! Shane here. Want to introduce myself and my truck. I have a 91 Toyota one ton dually ex dolphin motorhome. Now just a Cab and Chassis. I will be starting a build thread very soon. Hope to see you there.
I have a build thread for it. I would link it here... but I don't know how. I will say that it is ever evolving.
Just so you know those steel wheels have a weird bolt pattern. I think it something like 6 lug by 7.25”. There are no aftermarket wheels with that bolt pattern unless custom made. Treat them gently.
Yes, I knew that going in. Tires are extremely hard to find at the weight rating I need. also. They are only 14". Plan on going with GM dually parts eventually. Just for more wheel/tire options.
This is the tire most often used by motorhome owners. Load range D in 14”.even if you swapped the rear axle for something heavier, you would still have the 6 lug front hubs. https://www.prioritytire.com/thunde...MI876fka6UhAMVyB-tBh0XHAIoEAQYAyABEgIm1_D_BwE
That's awesome! Thanks for that, exactly what I was looking for! My plan, eventually, is to replace both front and rear components with GM one ton dually parts. All the suspension will be custom fabricated. That way, I can have standard 8 lug dually wheels all the way around.
I installed a GM 14 bolt ff rear axle on my rig. I’m light enough to switch to single tires in the rear, which is what I wanted to do. Can’t beat those 8 lugs.
