Driver door lock 91 2wd
Discussion in 'Maintenance/Repair' started by Mel, Sep 18, 2023.
  1. Mel
    Mel Newbie
    So I cant unlock my driver door anymore and it just randomly happened. Not too sure what caused this but if anyone else has had this issue how did you fix it? Or what can be causing it?
  2. fred heath
    fred heath Addict
    Raleigh, NC
    Try shooting some WD40 into the lock cylinder itself. Use a small screwdriver or awl to move the outside dust cover before shooting the WD40 inside. Doesn’t take a lot.
  3. Ponyryd
    Ponyryd Enthusiast
    What happens when you try it? Mine sometimes just moves the lock a bit, have to jiggle it and pull the handle at the same time, eventually it works. Gonna change the latch, really can’t be anything else.
  4. jetas
    Does the key go in?
    Does the cylinder turn?
    If no, start by spraying wd40/pb blaster or something and try to cycle it.
    if yes to the above ?s, then the linkage probably popped out the handle. The plastic retainers go bad. Or worst case scenario something is very wrong wit the latch
  5. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    ^^^what he said. But I'd use a fine powder lubricant instead of wd40/bpblaster in that cylinder. That's what I used when mines seized up. If the linkage did come off, you will have to go in through the other side and either pop the lock up/open by taking the panel off.
  6. jetas
    My bad, yea i forgot the detail of going in thru the inside of the door panel to repair
  7. Mel
    Mel Newbie
    The key does go in but I can’t turn it either way, it moves just a tad bit. I’ve been going through my passenger door to unlock it.
    I’ll try the fine powder and see if that helps! Thank you everyone
    Erwin Merida likes this.
  8. Ponyryd
    Ponyryd Enthusiast
    ^Similar to mine, try turning it while pulling the outside handle, works for me most of the time, but it’s most likely a bad latch.
  9. jetas
    Did your key work on that cylinder before?
    Mel likes this.
  10. Mel
    Mel Newbie
    Yes it did
  11. Erwin Merida
    Get a new set of lock cylinders with a matching bed lock and update all of it! IF, it's not the hardware/rod that broke. But if you can still pop the lock tab then it's your lock imo
  12. Mel
    Mel Newbie
    So I tried this and it actually opened like this!
    Ponyryd, jetas and Erwin Merida like this.
