it might be you need to bend the brake proportioning valve rod a bit to get it correct again. as the axl gets closer to the frame the rod opens the proportioning valve to give more power to the rear brakes.
how to adjust it here http://www.autozone.com/addVehicleI...pping/repairGuide.htm?pageId=0900c1528004da2c
Thank Sho. I've also found this... http://www.off-road.com/trucks4x4/article/articleDetail.jsp?id=186210
meh on frenching them in I would just run slider shackle that is what I plan to do they work very well
Mono leafing isn't good for long term. You can get away with it for a low end cheap drop but should really be avoided since there are better methods out there. Here's an example... LEAF SWAP / 5 TO 6 LUG / PICS / S-Dad Mod - CustomTacos.com Forum
