Disc swap or replace current brakes?
Discussion in 'Pre-1975 Build-Up/Project Threads' started by THorn, Dec 15, 2020.
  1. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Afraid of that. A lot of debate if any are safe. But its agreed the slip in style with longer studs is the way to do it if you have to.
  2. jetas
    Agreed. I think 5mm is the thickest id go without swapping studs
    THorn likes this.
  3. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    I didn't even think that style was offered is such a small of a size. Not much room to capture the lug before it becomes a hole it could go through. Mostly see guys running those trying to make up a ridiculous amount of space.
  4. THorn
    THorn Member
    Portland, OR
    1974 Hilux
    Yes, I arbitrarily posted the original stud dimensions. The ones that come with the spacer would be longer, which is a potential weakness I might think?
    Pearce likes this.
  5. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    I would think that them being weaker is going to be minimal. It's not like 10mm adds a bunch of leverage.
  6. jetas
    Once everything is torqued down it basically becomes like one piece. Its not like you ate putting all the weight/pressure on the very ends of the studs
  7. THorn
    THorn Member
    Portland, OR
    1974 Hilux
    Yeah, I feel just fine about using a 10mm slip on spacer to correct the offset. The only other question then is how far out does the center flange on the disc hub come out. If it's taller than 10mm then I’d need a flat one without a flange extension.
    Between this and the ss hoses, this project just got a bit spendier.
  8. jetas
    Dont forget about the hardlines
  9. THorn
    THorn Member
    Portland, OR
    1974 Hilux
    Yeah, I had just assumed new ones. I can’t decide if I want to try to buy them premade, or get tubing to fabricate them myself.
  10. THorn
    THorn Member
    Portland, OR
    1974 Hilux
    Hah, I’ve opened quite a can of worms here. As I figure it, the disc project is about 2x the cost in parts of replacing the original system, and quite a bit more work. However, I think it’s going to make me a lot happier with this truck in the long run. Hell, it’s got this monstrous engine in it, so it only makes sense to help it stop better as well.
  11. jetas
    You can get the pre flared lengths of line at the parts store.
    How far is Tumwater WA from you, theres a 77 there at the pick n pull
  12. THorn
    THorn Member
    Portland, OR
    1974 Hilux
    [QUOTE="jetas, post: 238222, member: 1097
    How far is Tumwater WA from you, theres a 77 there at the pick n pull[/QUOTE]
    Ah, good to know! I think I saw that in a recent part search. It’s only about 2 hours North, and a good excuse to visit my Seattle peeps.
  13. jetas
    Ah, good to know! I think I saw that in a recent part search. It’s only about 2 hours North, and a good excuse to visit my Seattle peeps.[/QUOTE]
    If you can get the spindles and calipers from that one you can find the rebuild kit on rockauto for the calipers and save some $$
  14. THorn
    THorn Member
    Portland, OR
    1974 Hilux
    If you can get the spindles and calipers from that one you can find the rebuild kit on rockauto for the calipers and save some $$[/QUOTE]
    DAMN! Just missed it. It was crushed yesterday.
  15. jetas
    DAMN! Just missed it. It was crushed yesterday.[/QUOTE]
    Well that fckin blows.
  16. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Well that fckin blows.[/QUOTE]
    Wow really! I was thinking I might as well go and get the hood even tho it might not work. It was under 50 bucks.
  17. THorn
    THorn Member
    Portland, OR
    1974 Hilux
    Yeah, what a drag. I was hyped to find one in driving distance. I have several misc bits I’d love to score.
    Luckily I think I found some spindles/knuckles/hubs close to home.
  18. THorn
    THorn Member
    Portland, OR
    1974 Hilux
    Wow really! I was thinking I might as well go and get the hood even tho it might not work. It was under 50 bucks.[/QUOTE]
    I'm curious if the later hood would work. They seem to be the same sheet metal, without the T badge on the front, but I haven't had the chance to examine the hinge mounting to compare.
  19. jetas
    Supposedly the hoods are the same minus the Emblem on the early trucks.
    il say this, fenders are slightly different in the area behind the bumper.
    door hinges are slightly different but im pretty sure the doors are identical
  20. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    From what I read the later hood will not latch on an early model because the core support is different.
