Daily 1990 2wd xtra cab
Discussion in '1989-1995 Build-Up/Project Threads' started by EJay, Mar 20, 2016.
  1. EJay
    EJay Member
    Tri-Cities, Wa
    90 xcab
  2. EJay
    EJay Member
    Tri-Cities, Wa
    90 xcab
    Can't wait to get rid of these rims. However, haven't really decided exactly what kind of rims I want on it yet. And thanks man, a lot more left to do still!
  3. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    One of these days I want to check out your headlights. I've been thinking I need a set of them. What bulb do they take, I assume an H1?
  4. Orlando Muniz
    Orlando Muniz Veteran
    Pflugerville, TX was Sac Town, CA
    89 Toyota Pickup
    Yep I know how that goes....it's an endless project...I'm real interested in the headlamp as well and how they turn out. I was looking at the LED Version as well. Lol only a few are still rocking the 2wd grille...
  5. EJay
    EJay Member
    Tri-Cities, Wa
    90 xcab
    Correct, an H1 bulb. I'd love to swing by and show them to you, I could use some help with some wiring on my marker lights, as I currently lack a soldering iron. I'll shoot you a text some time and see what's up.
  6. EJay
    EJay Member
    Tri-Cities, Wa
    90 xcab
    They're very high quality, definitely recommend them. Made of polished glass instead of the usual plastic and have a 5 year warranty. I'd say stick with HID; they don't require the cooling LEDs need and they have a much higher light output when compared to LEDs of the same wattage. And I love my 2wd grille! The Toyota script on the front is awesome I think.
  7. White Trash
    Eastern WA
    Other than this weekend I'm free till the 13th so bring it on by and I'll fix you up.
  8. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    You should do a video on the output of your new headlights...
    I've been curious, but too cheap to take that leap, lol.
  9. EJay
    EJay Member
    Tri-Cities, Wa
    90 xcab
    Will do man, but mine are 35W so not too bright. I'll do that once I adjust them though, for sure.
  10. EJay
    EJay Member
    Tri-Cities, Wa
    90 xcab
    Got some sr5 buckets from the junkyard for 40 bucks, only had two small tears in the driver's side seat, so I sewed them up and colored the seats with duplicolor fabric and vinyl paint. They came out pretty good I think! Bolted them up, one didn't match up in the driver's side, so I'll need to drill a hole, but I think they look awesome! [​IMG]
    Notryonlydo likes this.
  11. EJay
    EJay Member
    Tri-Cities, Wa
    90 xcab
    Before and after. I have no idea how to mount my 4 runner center console. Wishing I just bought an SR5 pickup one, since they have more space inside. I'll probably eventually fabricate something with it though. If anyone knows how to mount one of these let me know, I couldn't find anything online. [​IMG]
  12. Orlando Muniz
    89 Toyota Pickup
    Ya my 4runner seat didn't line up on the driver side either...which bolt was it?
  13. 90DailyDriven
    90DailyDriven Veteran
    New Mexico
    90 standard cab 2wd short bed
    You can pull the carpet forward and see where the bolt holes are for the center console. They might be covered with a piece of tape from factory.
  14. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    Seats look nice.
  15. EJay
    EJay Member
    Tri-Cities, Wa
    90 xcab
    The front right bolt. I just made the rear right share a bolt with the seat belt. Seems ti work fine.
  16. EJay
    EJay Member
    Tri-Cities, Wa
    90 xcab
    I will have to do that I suppose. I'll just wait until I get some replacement carpet and go from there. Mine is crumbling lol
  17. EJay
    EJay Member
    Tri-Cities, Wa
    90 xcab
    Thank you man! They're not very soft due to the fabric paint, but they're fine as long as you're not sitting in them naked. Lol
  18. Orlando Muniz
    89 Toyota Pickup
    yea i painted my original seat and yes it makes them very hard.....hence why i swapped over to leather seats.... As for the center console im in the same boat as you... there maybe some bolt holes there but its still going to require a bracket. When i mine off the 4runner the bracket was welded on. So we prolly are going to fab up some brackets for it.
  19. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    I can suggest, drill out the welds on the bracket to the floor pan, or make one, then bolt that to the floor with either nutsters or threaded rivets, hell even rivets. Then bolt the center console to that. Hope this gives u guys a good idea..
  20. EJay
    EJay Member
    Tri-Cities, Wa
    90 xcab
    Yeah I was thinking I would need to make some kind of bracket for it. That's okay, I was also thinking of figuring out some kind of way to utilize all of that unused space in the 4 runner center console, since they're supposed to be filled with a heater. Probably gonna cut it into two pieces, line it, male some separators, and put either a hinge on the back (easy route) or some kind of sliding mechanism on it. The slider would be really cool.
