Hello! I'm currently in process of redoing a few things on my Bagged and Body Dropped 92. I have power steering and I would like to build a custom high pressure line. I have the factory one still and would like a cleaner look and get rid of it and build a shorter custom one. I have searched the forums and didn't really see to much on a custom high pressure line. I'm wondering what you have done and what options I have or part numbers to go by to make a much shorter cleaner one? Im assuming I need to keep the banjo? Any insight or link to a build thread that someone may have done this is appreciated! Pics to come of the redo!
If you want custom, and clean id advise you on a electric pump setup with stainless lines and AN fittings. The MR2 roadster had this setup so OEM Toyota parts are available for Daily reliability. It would also free up the engine band a bit and you can have assisted steering while the truck is off..
I will do some research on that, but specifically I am just looking for an option to shorten the line and get rid of the excess length. I think I may take the line to a Parker location and see what they can come up?!
