crown vic wheels
Discussion in 'Wheels/Tires' started by trackfox, Dec 9, 2011.
  1. OldSchool84DevilLux
    OldSchool84DevilLux Enthusiast
    Marysville, CA
    1984 Toyota Sr5 PU Xtra Cab(Hilux)
    Theres plastic hub centrics on some vehicles how is that goin to help lessen the stress on the studs? Conical nuts are meant to center the rim. My buddy put his on back wards and the rim didnt seat correctly
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Most aftermarket wheels are made with the largest hub size available in that particular bolt pattern so they don't have to make 12 different hub diameters and thusly the tire & wheel stores don't have to stock them.
    You do what makes you feel all warm and fuzzy inside and I'll do what I know works without ANY issue and we'll both be happy. :D
  3. SuperRA
    SuperRA Newbie
    How are toyota studs designed any differently than studs on non hub-centric vehicles? They aren't... It's still a threaded stud... which works just fine on non hub-centric vehicles all day. The toyota studs are in fact thicker than studs on alot of 60-70s cars which are heavier and non hub-centric as well.
  4. craigdbl
    craigdbl Guest
    Discount tire sells these. They look the same. they are by Drag--dr44/[​IMG]
  5. Madness
    Madness Enthusiast
    Westminster, Co
    on top of that the toyota 6 lug trucks are lug centric...
    Hub rings are there for hub centric cars to "center" the wheel so there isnt any vibration while driving. Cheap ass plastic rings that usually snap when installed will not hold the weight of a 1-2 ton vehicle, The lugs do, hence why the lighter 2wd trucks have 5 and the heavier 4x4's have 6.
  6. speede
    speede Member
    Hey what's up. I jut put the same wheels on my 78 today lowered it and all. I'm getting a shaking at about 65 miles per hour. Iri balance the wheels and it still shakes can anyone help me with some info please . I do not have center rings thank you for your time
  7. speede
    speede Member
    And where can I buy the right size hub rings and what size!
  8. Ahshiet
    Ahshiet Enthusiast
    Stud stress? I must be pushing my luck cause I have 15x10 with 40 et and enough camber to have a big puddle sitting on the lip and no bump stops nor torsion bars yeah it's stupid but it's low n static it's not a race car built for fun!
  9. speede
    speede Member
    i put the wheels of a mercury grand mar. im still getting a shacking at about 60 so im thinking i need hub rings .i have seen the frist post and he has the same wheels with no hub rings so i dont know why i would need some. they only way to get some is by having someone make them. any ideas??
    78 3ich drop blocks rear
    3 coils in front
    mercury grand m. wheels
    thanks!
  10. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    which one 77/78/79/81[r.i.p]82 sbrc driftbox, and a CeliLux/current daily= 79 sbrc [lil' blue]
    could be pinion angle with the 3 " blocks i got a little vib. with my 2" blocks so check that the drive shafts not binding up
  11. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    oh i got g.marquis wheels a and they fit perfect no wheel vibration at all cept. for that dang blown shock ive been meaning to replace
  12. TDS909
    TDS909 Veteran
    ONTARIO
    1992 st cab
    how much did you guys pay for your crown vic rims?
  13. memphis_r27
    memphis_r27 Newbie
    Hey guys, I'm new here... First of, I just want to day thanks for all the great info here.
    Although I don't own a truck, sorry, I do have a set of crown vics I want to install on my 94 Camry. Do you guys know if I would need spacers to clear calipers??? Please help.
  14. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    I doubt you will have any problems...these wheels will probably be sticking at least 3" outside of your fender!
  15. AspireCycle
    AspireCycle Member
    Phoenix, AZ
    1978 Longbed 5 Speed
    Just so you guys know, there are three different "versions" of these 16" wheels....
    The Crown Victoria version has a double stepped lip, and a lower offset (more poke). The mesh "spokes" are made to look like they overlap, and the star pattern around the lugs in the middle has a straight solid border.
    There are two different Lincoln versions, from the Grand Marquis or Towncar, maybe the MKVII. One version (V1) has a single stepped lip, higher offset (less poke). The other version (V2) has a double stepped lip like the crown vic, and a lower offset (more poke). The mesh "spokes" are FLAT, they look more like ENKEI 92's, and the star pattern around the lugs in the middle has a jagged edge.
    I ended up getting the Lincoln version, two of each, so I can have a staggered set. On my '78, the rear hubs are tucked further under the bed, so both front and back will be flush with the fenders, and the rear wheels will have more lip. Good luck with your search!!
    PICS ATTACHED
    John Burger and kayyo like this.
