ok guys if your like me your tired of lookin for that chargeing problem with your alternator ... not enough or its overcharging ,,, heres the fix autozone had a one wire alternator for 53 dollars buy it and a company called L C E performance sells a solid welded bracket with uppr and lower mounts with new bolts !!! i know isnt it great,,, and it just bolts on and you still use the original pulleys thats all ,, it sells for 44 dollars best thing is it only takes a half a hour to do ..noy you have 100 amps of juice far every thing u need in your ride !!! hope it helps you out ,,,, randy
