1. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Good truck, good workbench
    Toyotashack likes this.
  2. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Good luck!
  3. Justin Danger
    Bay Area Peninsula
    Failed smog.
    I showed up first rhing in the morning, and the machine hadn't booted up to check yet, so I sat with the engine running to keep things hot. I noticed that things looked a little lean on my wideband, so I adjusted the afm a little richer. Ran just fine, nice and smooth, held 14.7 at idle. Boom, failed smog because it was too rich. I shouldn't have touched anything!
    I went home, adjusted things back to where they were, and then it was running waaaay lean. Like didn't accelerate and sputtered lean. I've been messing with it, and now if I get it in the right range, it is super jumpy holding a consistent speed jumping between 15 and 16.
  4. Erwin Merida
  5. Justin Danger
    Bay Area Peninsula
    So I started the engine this morning, waited til it got up to temp, and took it for a few drives around the block. I tuned it to where it was running at around 14.7 AFR while driving at 25mph. I then turned it off, did some things, went back to turn it back on, and the AFR was off the charts lean. WHAT IS GOING ON?!
    I ordered a new O2 sensor to see if that changes anything. That won't come for days, and my registration is up at the end of March.
    I may try seeing how well I can get it to run with the O2 sensor unplugged to see how that does.
  6. Erwin Merida
    Other than tinkering with the afm, what else did you adjust?
  7. Justin Danger
    Bay Area Peninsula
    Timing. Other than that I don't know what to try. It is also running rich one minute, lean another, on point later, even without adjusting anything. I have NO idea what is going on
  8. Erwin Merida
    Crayz to say, but an O2 sensor would cause this condition. Also, check that you didn't knock an injector connector loose/off you can have lean conditions. Does it sound like it's misfiring any?
  9. Justin Danger
    Bay Area Peninsula
    My wideband O2 sender has a narrowband output, so I ordered a harness to hook that up. Then I know the ECU is seeing exactly what I am
    Erwin Merida likes this.
  10. Justin Danger
    Bay Area Peninsula
    I've been opening and closing my hood a lot lately trying to tune things, so I made it a lil easier on myself and added a couple hydraulics.
    brackets are just aluminun, and the hydraulics came with the ball nuts.
    This morning I will be installing a brand new MAF and O2 sensor as well as my FAST ignition module. Hope this helps with keeping things stochiometric.
  11. jetas
    Good idea with the lift struts. Been debating on doing the same.
    Piece of advice, round off those corners on the hood bracket OUCH
  12. Justin Danger
    Bay Area Peninsula
    Hahaha, totally! they definitely need some refinement, I just roughed those out for proof of concept.
    new sensors and things did not work out. that leads me to believe that there is a fault in the wiring somewhere causing things to react inconsistantly. I have no idea where to start, there are lots of wires under that hood haha.
  13. Justin Danger
    Bay Area Peninsula
    I'm thinking that I need to check the wires for the AFM, the O2 sensor, the TPS, and the temp sender. Is there any other sender that might affect the air/fuel ratio?
  14. Erwin Merida
    Damn. Timing?
  15. Erwin Merida
    Cold start injector? Cool mod for the hood. What vehicle are those from?
  16. Justin Danger
    Bay Area Peninsula
    Timing is spot on 5*
    CSI is a suspet too.
    They are just hydraulic assists for a camper shell or something. they are 18.5" and rated for 45lbs.
  17. Justin Danger
    Bay Area Peninsula
    *Funny enough, my idea for the hydraulics on the hood was inspired by an old post that that bogus account Chinafodia posted on.
  18. Toyotashack
    Toyotashack Enthusiast
    Monroe, WA
    77 hilux 92 2wd 89&90 runners
    Find the prob? Was it not the MAF or TPS?
    Fuel damper. Fuel pressure regulator. Maybes..
  19. Justin Danger
    Bay Area Peninsula
    I took her back to the shop that I had her at a while back to readress some things they left hanging last time, and to checl things out. They are smogging it tomorrow to see if it passes after they worked on it.
  20. Erwin Merida
    Hopefully they make it work.. are you running bigger injectors?
