1. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Oh, yeah, I definitely went the expensive way. Part of that was how much I enjoy the 22rte engine, and partially a big insurance payout from getting hit by a car on my bike. I have also done a lot of work on my engine, but have never built an engine from bottom to top. This seemed like a great way to get that experience and get a badass engine.
    All in all with all of the big and little things from the engine parts to the ignition system and every little nut and bolt I replaced it is probably looking at about 3K..... so what I paid for the Truck hahaha
  2. mutantcolors
    mutantcolors Enthusiast
    That is what I was looking at for a rebuild to net like 110hp.
    So far I'm +$100 on my 1UZ VVti...but it ain't gonna come easy once I crack into the project.
  3. Justin Danger
    Bay Area Peninsula
    Been doing a lot of pondering on new tires. I need them, and have been thinking of changing size. I'm currently running 205/65r15 on 15x7s and think I may go down to 195/55r15. It'll give me an inch of drop, and calculations show that it should even make my speedometer read right.
    ace89 likes this.
  4. mutantcolors
  5. Justin Danger
    Bay Area Peninsula
    Just got some clear corner lenses in, and am getting an 82 grille mid section so splice into my grille as well as some 7" round headlight buckets. New engine And a facelift..... gonna be a cougar of a truck?
    ace89 likes this.
  6. Justin Danger
    Bay Area Peninsula
    Finally the engine is back under the hood!! My girlfriend and I had some fun wrangling the engine into the bay and mating it to the trans. I definitely now know why I was told that it is easier to drop the engine in with the trans attached. Never the less, everything ended up mating up nicely. I was able to get 3 bolts into the bell housing before leaving on a vacation, so cranking the engine will have to wait another week.
    KS.ID and jetas like this.
  7. mutantcolors
    Very nice man. You've taken the lead on this forum for GETTING SHIT DONE.
  8. Justin Danger
    Bay Area Peninsula
    thanks man, I just can't stand not driving my truck. bout time to crank er over.
  9. Justin Danger
    Bay Area Peninsula
    Finally almost done. I have a leaky fuel injector o ring, and the starter isn't engaging. Gonna pull the starter to check it out, and pull the intake plenum to get to the fuel rail. Two steps forwards and one back.
  10. mutantcolors
    Did you change flywheel or something out of the ordinary?
    New off brand starter?
  11. Justin Danger
    Bay Area Peninsula
    nope, all is the same. crank turns easily by hand, so thats not the problem.
    I have tomorrow morning off and hope to get more done then. My focus now is to get the fuel to stop spraying everywhere.
  12. Justin Danger
    Bay Area Peninsula
    The fuel issue is resolved, starter is pulled. Tomorrow I will give it a test and see whats up.
  13. Justin Danger
    Bay Area Peninsula
    Engine starts, runs at a low idle, then shakes and dies.
    I will try to snap a video to post
  14. Justin Danger
    Bay Area Peninsula
    I really don't like any of the noises that the engine made here. Please anybody with engine knowledge, do you have any ideas what is going on here? The engine rattled, then squeaked before dropping idles, and shaking itself to death. I'm not sure where to go from here...
  15. Justin Danger
    Bay Area Peninsula
    Sounds like rod knock (how do i diagnose and fix?), would that cause the motor to shake itself until it dies like it does in the video?
  16. jetas
    Could be that or your timing is way off. He is what mine sounded like when it was knocking
  17. Justin Danger
    Bay Area Peninsula
    oh, yeah, that is a lot more thud than tin can rattle. I just haven't been able to get it running steady enough to check the timing. from where the distributor rotor was at TDC, it looked spot on.
    And I am doing this all with the timing retard disabled, so it is just a basic ignition setup to get things going.
  18. jetas
    Does it sound like its up top or down low?
    If it sounds like its up top could be the rockers tapping the valve cover. The 4 nuts Shouldnt be on more than hand tight
  19. mutantcolors
    Way beyond my level of help, hope you get it sorted with no issues.
  20. Liquidhandwash
    Liquidhandwash Enthusiast
    Northen VIC
    1980 diesel
    Almost sounds like the engine is starting to sieze up, you got good oil pressure? does it run when cold then as it heats up runs rough then dies? could be the engine temp sensor for the ecu has failed or has a wiring issue, on that sensor
