1. Justin Danger
    Justin Danger Veteran
    Bay Area Peninsula
    so here is the eye candy:
    The rods, and some other odds and end bits
    New head, cam, and rocker assembly
    over sized ss valves and all that jazz
  2. Justin Danger
    Bay Area Peninsula
    The block finally came!
    Soon I shall begin taking apart the old engine, and swapping some over to the new.
  3. Justin Danger
    Bay Area Peninsula
    Teardown is going well... well, was going well. I have just tried with every ounce of effort in my body to release the bolt on the harmonic balancer to no avail. But intake, head, and exhaust manifold are all off. I spent last night quite deep into the wiring schematic world for my ignition. I have been using the F.A.S.T. I6 system from LCE, and just got the boost proportional retard controller, so that should hopefully give a little better power and fuel efficiency.
  4. mutantcolors
    mutantcolors Enthusiast
    If you had it running, the old bump-the-starter thing works well. BUT you are disassembled...
  5. Justin Danger
    Bay Area Peninsula
    disassembled. but not completely unwilling to plug the starter in for a bump. After jumping on a breaker bar for a few minutes, I wonder how much power that starter motor has tough....
  6. jetas
    It has enough to break that bolt loose.
    Unless you can get an impact gun in there
  7. Justin Danger
    Bay Area Peninsula
    Well, it is impact time. Starter wasn't strong enough to break it free. I think one of my buddies at work has an impact, so we shall see if that works.
    jetas likes this.
  8. mutantcolors
    Crazy, we were able to break my 1JZ bolt free with a cheesedick air impact, and those things are notoriously tough.
  9. Justin Danger
    Bay Area Peninsula
    I ended up with this 4 foot steel pipe that we use at work for wrenching or going Office Space on electronic devices. That did the trick. I thought that I had just torn the block of the engine mounts by the time the bolt gave, but it gave none the less.
    take that, bolt.
  10. mutantcolors
    And that kids is why you don't reuse crank bolts!
  11. Justin Danger
    Bay Area Peninsula
    Successfully pulled what was left of the old motor today. I have been taking it apart piece by piece and cleaning everything. Now while I wait for some parts I can clean the engine bay out and neaten up some of the wiring.
  12. Justin Danger
    Bay Area Peninsula
    New motor is almost ready to be dropped in! I'm just going to wait the rain out until I actually go for it.
    22r short block from LCE, ARP main studs:
    Forged pistons .020 over, dual row timing chain:
    DOA Racing head with custom cam grind, rebuilt injectors, and a lot of bolts replaced with acorn nuts on studs:
    And everyone's favorite..... vacuum lines!
    I got my upgraded alternator yesterday, so will soon be installing that, engine mounts, and start wiring up the new ignition system.
  13. Justin Danger
    Bay Area Peninsula
    spent a while the other day cleaning out the engine bay. It was quite roomy actually
  14. mutantcolors
    Any reasonable power estimates? I guess about 150 with all the head work and bore.
    Hell, with the studs you can probably crank up the boost eh. Get 20 psi in that bitch!
  15. Justin Danger
    Bay Area Peninsula
    I'm not sure what power it will be pushing. Stock is 135 hp (101 kW) at 4800 rpm and 173 ft·lbf (234 N·m) at 2800 rpm. 150 would be nice. I am pushing about 9lbs of boost, I hear 10psi is when you run into fuel problems.
    Truck was powerful before, any gains I will take. I am also hoping it will be a little more efficient for my road trips.
  16. mutantcolors
    That is some nice torque in the right spot.
  17. Justin Danger
    Bay Area Peninsula
    yeah buddy! I have actually planned on taking it to a dyno when it is all done, but may upsize my exhaust too, so it may wait til after that.
  18. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup 04 camry
  19. Justin Danger
    Bay Area Peninsula
    Thanks man! It sure has been fun.
