BELLTECH DROP LEAF SPRINGS (PART #5978)
Discussion in 'Suspension/Chassis' started by Xee Xiong, Aug 4, 2017.
  1. Xee Xiong
    Xee Xiong Newbie
    89' toyota pickup
    Any one have any luck with these? I have an 89 pickup 2wd and bought the 3" drops. did not line up with my hangers at all. they were longer. just seeing if anyone had luck with straight bolt up
  2. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Where did you buy them from? A lot of online vendors' "will it fit?" have the wrong part numbers on them. Double check your springs with Belltech fitment suggestion.
  3. Xee Xiong
    Xee Xiong Newbie
    89' toyota pickup
    I got it off of summit racing and cross referenced it with belltech site to confirm. tried installing them today and ran into the issues. called belltech and everything comes out with their measurements. lined it up with the stocks and the bell techs were longer
  4. Justin Danger
    Bay Area Peninsula
    interesting.
    Well, I know that the 5976 are shorter. They are what I have on my truck, and 5978 were the ones that I got misshipped a few times. I don't know what the difference is between the 86 and 89 mounting distances for leafs are, but maybe try the 5976s.
  5. Xee Xiong
    Xee Xiong Newbie
    89' toyota pickup
    yea, the 5978's were way too long. I'll give 5976's a try. thanks man
  6. VolksYota
    VolksYota Member
    Buffalo
    89 pickup
    Just installed my street edge 3'' drop leafs on my 89 and had the same issue. I persuaded them to fit by swinging the shackle all the way back and applying some pressure to get the front holes to line up. They advertised to fit 89-95 trucks so I'm wondering if my truck had the 88.5 setup you referred to in your other post. The street edge leafs were also longer than oe ones when standing next to each other
  7. Xee Xiong
    Xee Xiong Newbie
    89' toyota pickup
    yea, you will need the 5976s and they will fit perfectly.
  8. smallz
    smallz Newbie
    Maui, HI
    89' Extra Cab
    So does this go for all 89's?? I'm about to order belltech drop leafs and wonder what part number I should order. 5978 or 5976??
  9. hawaiiysr
    hawaiiysr Member
    Oahu
    93 single cab
    did you get this figured out? i have a 93 and it calls for 5978 leafs as well. id rather not run into this issue. do you have a measurement from hanger to hanger and the length of the stock leave vs the BT 5978 leaf length?
  10. Xee Xiong
    Xee Xiong Newbie
    89' toyota pickup
    sorry for late reply. but i think you'd only would run into issues with the 88 and 89
  11. The Count
    The Count Newbie
    Having this issue right now with my 92 and the 5978 leafs
  12. The Count
    The Count Newbie
    Has anyone ever taken a measurement of the originals against the 5978 and 5976’s?
  13. VolksYota
    VolksYota Member
    Buffalo
    89 pickup
    To revive this old thread / the saga continues. After making the costly exchange for 5976 they came in, looked fine and have collected dust until today. I went to install and was met with a new problem. It seems the bushings are wrong. The front bushings are a larger inner diameter and the rear ones are too small for the bolt to fit through. Any ideas or perspective would be appreciated.
    [​IMG] [​IMG] [​IMG] [​IMG]
  14. VolksYota
    VolksYota Member
    Buffalo
    89 pickup
    Also when this may be of interest. Suspension source sent me the spec drawing when I was trying to make an exchange. This is the 5976
      File size:
      114.1 KB
      39
  15. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    I believe my bushings were reversed when I got my leafs...just swap the bushings from front to rear and rear to front, so the spring can still be installed as marked ("Front" forward).
    Does that appear to be your case?
  16. VolksYota
    VolksYota Member
    Buffalo
    89 pickup
    Yeah that's exactly what seems to be the case. Were you able to remove the bushings without damaging them? If so how did you do it?
  17. VolksYota
    VolksYota Member
    Buffalo
    89 pickup
    bump. Anyone have advice for removing bushings without ruining them so I can flip flop my bushings?
  18. Justin Danger
    Bay Area Peninsula
    they're not hard to pull, at least mine weren't. it is really two bushings, one on either side. Remove the metal sleeve from inside, then just pull from both sides.
  19. VolksYota
    VolksYota Member
    Buffalo
    89 pickup
    Awesome, I'll give that a go. thanks
