Backspacing??
Discussion in 'Wheels/Tires' started by Collin Ramos, Mar 3, 2020.
  1. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Common way to swap to a different lug pattern involves a wheel spacer lug adapter, which is probably a minimum of ~1" thickness, so keep that in mind when looking into wheels
  2. Collin Ramos
    Collin Ramos Member
    Can’t seem to find anyone who even makes 5 lug to 4 lug adapters. Always the other way around lol.
  3. Collin Ramos
    Collin Ramos Member
    Btw, seen some pics of your truck! Nice interior brotha!
  4. Perkolator
    Placer County
    1975 Hilux
    Thanks
    I dunno where you were looking but I just Googled it and saw many adapters for going either direction between 5 and 4 lugs
  5. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    I'm going to throw this out there as well. Could allways fill and drill for different lug patterns. Will be expensive but can be safer done right.
  6. jonathan lee
    jonathan lee Member
    Bellingham Wa
    1977 Toyota SR5 pickup
    I have a 77 SR5 pickup for the individuals running 17"x9.5" or 18"x9.5" square setup what offset are you running
    I read a old post on a different site and guy said he was running 17"x9.5" -10 offset and they were tucked and on a 4"/3" drop I am currently at stock hight but what are you all running in that range that is tucked or at least clears the wheel well. Pictures would be awesome as well if possible
  7. jetas
    I test fit a 18x9 +40 up front and they would rub the firewall real bad.
    jonathan lee likes this.
  8. macawilial
    macawilial Veteran
    Born and raised in San Diego
    Don't forget about hub bore sizing. If the rim's hub bore is too small, adapters will be needed to push out the rim or you can have the hub bored out to fit
    jetas likes this.
