Backspacing??
Discussion in 'Wheels/Tires' started by Collin Ramos, Mar 3, 2020.
  1. Collin Ramos
    Collin Ramos Member
    I’m in search for some new wheels for the 78. But was wondering, what is the most backspacing I can have without the wheel touching any of the suspension components front and rear??
  2. Collin Ramos
    Collin Ramos Member
    I was looking at getting wheels with a 5inch backspacing all around.
  3. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
  4. Collin Ramos
    Collin Ramos Member
    What year jeep? Can’t seem to find those wheels, I found some in 15x7, but not 15x8.
  5. jetas
    Offset will depend on width.
    For reference, I test fit some 18x9 +40(ish) on 215/40/18 tires and they didnt touch any suspension component BUT the tire did rub the firewall. I also test fit some 15x8 with about a 5" backspace and those were more than fine but they poked out a good inch.
  6. Collin Ramos
    Collin Ramos Member
    These are 15x10s, but I wonder what backspacing he is running.
  7. Collin Ramos
    Collin Ramos Member
    Thank you! I’ll keep that in mind.
  8. jetas
    Pretty sure the offset is in the negative. Are you looking to tuck the wheels or have them poke out? If poke then just get whatever has a negative offset
  9. Collin Ramos
    Collin Ramos Member
    Okay I’ll keep my eyes open. There isn’t as much Japanese wheels for these trucks huh? Being that it’s Toyota and all.
  10. Perkolator
    Placer County
    1975 Hilux
    Hmm, I thought they were 8" wide, but could be 7" - I probably measured across the OD, not the ID where the tire sits
    There are tons of wheels that should fit these trucks - just find some in 5x114.3/4.5" lug pattern and go from there with offset/backspace.
    Collin Ramos likes this.
  11. Collin Ramos
    Collin Ramos Member
    So I actually had some time today to do some measurements, looks like 5.5 backspacing is the most you can go without hitting the strut. But don’t quote me lol it was a rough measurement
  12. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    The only thing I hate about the 5x4.5 bolt pattern is a set of work equip or any or those 4 lug wheels would look good on these trucks.
  13. Collin Ramos
    Collin Ramos Member
    That’s exactly my point! Ugh.
  14. Collin Ramos
    Collin Ramos Member
    I’m actually just gonna settle for a nice pair of steelies or centerlines for now, til I source a 5x114.3 jdm wheel one either 14inch or 15inch.
  15. jetas
    There are A LOT Of wheels with this bolt pattern. The bolt pattern is still used today on new cars. Just have to look
  16. Collin Ramos
    Collin Ramos Member
    You’re right. But the period correct Japanese wheel is what I’m after.
  17. jetas
    Can always swap to 4 lug, you wouldnt be the first
  18. Collin Ramos
    Collin Ramos Member
    never heard of that! I’m gonna look into it. Lol.
  19. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    "Period correct" wheels for Toyota trucks would be a 5-lug, 15x7 wheels.
  20. Collin Ramos
    Collin Ramos Member
    Well yes, period correct style, 15s. Something from the late 70s early 80s. Japanese wheel.
