AWD mini?
Discussion in 'Engine/Drivetrain' started by ffryno13247, Jan 4, 2012.
  1. CrazyCody93
    CrazyCody93 Enthusiast
    Gresham OR
    84 Sr5 Xtra cab
    if you did an RB motor, i know the rb26 somehow has the front differential grafted into the motor? should help suck up smaller to fit in the engine bay
  2. ffryno13247
    ffryno13247 Member
    Yeah the Vw motors have the tranny/diff and they d be a good fit but they are expensive as far as the awd system goes
  3. IronNam
    Yeah, it's because I saw a 5.7L from the Tundra at the local Showroom floor and the motor looked HUGE.
    How low do you plan to go?
    AWD R32/3/4's have a awd system like a traditional 4wd vehicle does. Separate front diff i believe.
    I wanna use STI AWD transmission, would be sick.
  4. ffryno13247
    ffryno13247 Member
    If I don't something other then Toyota I'm going with a subi. Cuz everyone already knows that it can handle monster HP.
  5. IronNam
    Nothing wrong with that.
    I lined my truck up next to my friend's STI before and the angle of the front wheels to the transmission seems to be similar to the Subaru's. that is if i wanted to retain the AWD. Pretty neat, i just wonder how to fit that flat wide engine with our frames lol.
  6. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Another idea is the Toyota RAV4 4WD Sport V6. 269hp, 244 torque. They are really quick. I drove one on our lot.
  7. ffryno13247
    ffryno13247 Member
    I ve actually been wondering about this set up I think they are a little more available. And alot cheaper!
  8. ffryno13247
    ffryno13247 Member
    I did some searching and the rav4 v6 is a 2grfe which is a pretty good platform I just need to find a wrecked one so I can measure it. But Id still like to find a 5spd for it.... If they exist
  9. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    CR-V drivetrain!!!
    But really I just think your being impractical.
    Why not buy a 4wd truck, lower it, put some limited slips in it, and the biggest motor you can fit?
    That would be MUCH easier than grafting a front wheel drive based suspension onto your RWD frame.
  10. ffryno13247
    ffryno13247 Member
    Mostly because I ve never seen one and I think it's a cool idea. I had thought about doing the 4x4 route but I want it lower then that and it's fun project
  11. IronNam
    I like the commitment to the idea.
    The 2GR-FE is a great motor. Mom's 07V6XLE is a beast with it, even for a +3300lb car it was tested doing the 1/4mile in 14.5!
  12. ffryno13247
    ffryno13247 Member
    Thank you!
    I'm hoping that the 2gr will still be fun. I'm hoping that it will since these trucks are so light
  13. ffryno13247
    ffryno13247 Member
    Thank you!
  14. confused.rat
    confused.rat Enthusiast
    Springdale, Ar
    1993 Pickup Ext Cab.
    saw a guy that put a 4x4 ford ranger on a 2wd frame. still had all the 4x4 equipment and worked. but it wasn't dropped. i can't see how it would. i'd figure the front axels would bind up with a drop.
  15. IronNam
    If I'm correct, the Taco's use the 4.0L version of the GR family, 1GR I think? I can't recall.
